Motherboards MSI Z87 G45 Which CPU temp is correct
Discussion in 'Hardware' started by crazymo, 1 Jan 2014.
  1. crazymo
    crazymo What's a Dremel?
    10 Feb 2013
    Hi all
    The main BIOS screen shows the CPU and system temperature
    However the hardware monitor gives a CPU temperature as well. This is usually 5/6 oC higher
    Why are they different and which one is correct.
    Also is there a quick way to see the CPU temp when you are playing a game ?
    Crazymo
    Enermax ECA3250-B Ostrog Midi Tower white
    VTX3D AMD Radeon HD 7870 Tahiti LE
    Arctic Cooling Freezer i30 CPU Cooler
    MSI Z87-G45-GAMING ATX Motherboard
    Intel Core i5 4670K
    G-Skill 8GB Ripjaws X DDR3 2133
    Evga 500w bronze psu
    W Digital 1 TB Caviar Blue
    Samsung 24x Retail SATA DVD
  2. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    You want Realtemp.
  3. TheMadDutchDude
    23 Aug 2013
    As above. Use RealTemp or CoreTemp.
  4. crazymo
    10 Feb 2013
    Tks guys
    Can RealTemp show you temperatures when you are actually playing a game
  5. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Regarding the BIOS readings: one will be reading package temp, the other will be reading 1st core temp. There's always discrepancy between the two as one's for the whole lot and the other is for one part.
  6. mrbungle
    20 Sep 2004
    Have a bash with the trial of Playclaw for overlays while playing games, it works very well.
  7. bulldogjeff
    2 Mar 2010
    I have always found HWMonitor to be perfect, tells me everything i need to know CPU, GPU, HDD and PSU voltages and it's free.
  8. crazymo
    10 Feb 2013
    The HW monitor is part of the MSI software which comes with the motherboard
    Its just a an icon on the main MSI menu which is why its so confusing so one screen says one CPU temp and another says a different temp
  9. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Grab hwinfo64 and interface it with rainmeter, set your cpu/gpu/whatever temps and utilization stats to always on top. This gives huge flexibility to what is shown, and you can make it look however you like with fonts, colors and etc. It works great, though there are a few titles here and there that seem to cause some weirdness like big blocks around the meter, flickering or meters not showing at all.
