Hardware MSI Z97 MPower Review
Discussion in 'Article Discussion' started by Dogbert666, 21 May 2014.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    Nice looking Mobo, but black and yellow..really???
    Very difficult to build a matching rig with that trim.....I really don't see any yellow trimmed SSD's, memory, LED case fans or braided cables...I know MSI do a yellow trimmed GPU but that's the only one AFAIK.
    It's not as if yellow really goes with anything else either...you'd really have to stick with black for all the other bits which would be a bit boring TBH.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Chuck in a Lightning graphics card as you mentioned, then just make everything else black, after all there's plenty of black on the market. If you want to go a stage further, pick up some paracord/sleeving and make some black and yellow cables, or just buy some from the huge number of guys offering custom sleeved ones nowadays. The Corsair RM series power supplies are also black and deep yellow.
    Not exactly hard to do a black and yellow/gold colour scheme nowadays, even with very minimal modding.
  4. DatenThielt
    DatenThielt What's a Dremel?
    4 Dec 2009
    AMD Mobo's please :(
  5. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    So they isolate the audio stage... then add backlighting?
  6. skunkmunkey
    skunkmunkey Minimodder
    15 Jul 2007
    My wife has a "resent button" I press it all too often....
Tags: Add Tags
