Apple MSN Messenger alternative
Discussion in 'Software' started by adam197, 4 Oct 2005.
  1. adam197
    adam197 What's a Dremel?
    22 Feb 2005
    Having a problem when using my iBook at uni, being that I cant get in contact with my MSN contacts as messenger is blocked (accessing net through university network in accomodation)
    Ive tried webMessenger but no luck, doesnt work with Firefox, Safari or IE.
    Has anyone any suggestions, prefferably web based as im guessing all IM applications will be blocked through the network. Any solution would be most appreciated.
    Thanks.
    PS - Apart from this iBook rocks (even though I know this is a MS problem). Everything "just works" and Eclipse is amazing.
  2. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    email the netadmin maybe they'll be slightly forgiving... just ask nicely... it may be that they've blocked those sites...
    but i'm not sure if they have any right to block common ports/websites in accom ...
    as i say give them a email or something... can't hurt to try ey?
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Not sure if this will work for you but at school we use MSN2Go It's pretty basic in terms of features but it works ;)
  4. adam197
    22 Feb 2005
    As long as I can talk to people Im happy enough.
    WebMessenger doesnt work as it isnt supported in the Mac browsers Ive tried (Firefox, Safari and even IE which is rather strange)
    Ill give msn2go a try when I get back on my iBook, its that kind of thing Im after, as long as it works on mac browsers. Thanks
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    The uni has the right to whatever it wants with the connection.
    The students sign the T&C of network access, if they don't agree they dont get network access. Simple as.
  6. quack
    quack Minimodder
    6 Mar 2002
    Indeed, just as any ordinary ISP has the right to block any port it wants to.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Indeed, and the majority of big universities run in almost the same way and are governed by the same laws.
    I enjoy quoting 'your network access is a privilege, not a right' to students when I catch them eating/drinking in my labs :p
  8. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    mean! good job I graduated now :D
  9. Atomic
    Atomic Gerwaff
    6 May 2002
    The undergrads learn within a few months that they dont eat or drink in my labs. Any other labs I dont care about, but Im more than happy to get security to eject them form the building if they break the rules...
    They have no excuse as there is a 3ft sign on the lab doors saying the rules.
    No eating
    No drinking
    No smoking
    Simple really.
  10. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    are you sure its blocked? for my uni network i just had to manualy enter the proxy details and socks5 stuff in to messanger.
  11. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
  12. Adnuo
    Adnuo Banned
    28 Aug 2005
    If it's blocked, no alternative client will solve your problem. The port is blocked, period.
    Oh, and as mentioned, they have every right to block any and every port/web address they want. They can block everything but www.google.com if they wanted. Hell, they could make you wear pink spandex and sing country music while using the net if they wanted :V
  13. Atomic
    Atomic Gerwaff
    6 May 2002
    I'd be surprised if they block MSN/Chat apps, there are no guidelines recommending the blocking of them that I know of...
    p2p on the otherhand MUST be blocked to comply with janet guidelines.
  14. Soulfly22583
    Soulfly22583 What's a Dremel?
    12 Jan 2004
    For an actual alternative program - I use adium... friend showed me it in class... works pretty well. Gives you ability to sign in with simultaneous screen names for AIM, Jabber, MSN, and Yahoo.
  15. adam197
    22 Feb 2005
    That would be the reason Im looking for a WEB BASED alternative, as I said in the first post. WebMessenger isnt blocked, just not compatible with Mac browsers for some reason.
    I have found one that works though - http://chicago.e-messenger.net/
    Quite basic but will do until I find something better.
  16. quack
    quack Minimodder
    6 Mar 2002
  17. Boswell
    Boswell Minimodder
    23 May 2005
    out of interest what uni are you at?
  18. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    The most likely solution is that you need to enter your proxy details to enable you to sign in.
    p2p isn't blocked on my campus, but they have the right to disconnect you if your computer gets port scanned and they find you using a p2p application.
  19. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    i went to two different universities, one uni didn't like msn messenger on their systems, the other actively upgraded to the latest version when ever it was released. It's just a matter of each uni's preference.
  20. Atomic
    Atomic Gerwaff
    6 May 2002
    They should be actively discouraging p2p unless your course has a reason to use it (which i highly doubt)
