In the last few days Msn Messenger is goin so slow, i type and the words appear a few seconds later. Anyone know if its a windows update problem? Using xp pro, everything else on computers fine, no viruses. Thanks
My msn had the same proble a few weeks ago, all i did to cure it was to reload msn and that has cured it. Also just clean out all your temp internet files, history and that may help to.
if messenger is being slow it's because of the actual MSN itself. As you know, your contacts are stored on their servers, not locally (unlike ICQ) therefore your communications go through a MSN server. If this server is being slow, or under heavy demand then it'll slow things down.
