Displays multi-monitor set up query.
Discussion in 'Tech Support' started by Toxic_Lemon, 4 Feb 2010.
  1. Toxic_Lemon
    Toxic_Lemon What's a Dremel?
    30 Jan 2010
    Hi i just started delving into multiple screens, is there a way i can get different items up on each screen without either A: dragging items/folders across or B: going into display and changing monitor from 1 to 3 ?
    I have a vga plugged into my mobo and a tft plugged into my 4850.
    Any ideas would be much appreciated.
  2. Jenny_Y8S
    Jenny_Y8S Guest
    Not sure exactly what you're looking for...
    Do you want certain apps to open automatically on one screen or another? If so, then windows will have a go at doing that itself (What OS are you using?)
    But for better control, try ultramon, it's a 40$ app but I've used it for years on multimon settups. http://www.realtimesoft.com/ultramon/
  3. Toxic_Lemon
    30 Jan 2010
    on one screen i will use it for monitoring stocks/shares and the other screen internet and games ,i have vista ultimate.
    Yeah what i want is to have apps on on screen and apps on another screen and when i open a app on say screen 1 i want it to open on screen 1 same with say screen 3 but the problem i have is when i open a app on screen 3 it open on screen 1 :/.
  4. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    Some applications will remeber where they where last opened and closed on other monitors others will always just pop up on the primary screen.
    Games will always genrally load on the primary screen as will most video players.
    Also what gfx card is on the mobo?
    As I seem to recall that vista does not support multiple video drivers to be loaded at any time.
    So is your only problem that you dont wish to drag an application from 1 monitor to another (which is pritty much the quickest method) or you could as mentioned pay $40 for ultramon, which will give you a drop down menu in which you can "send to monitor x".
  5. Toxic_Lemon
    30 Jan 2010
    Yeah i think i will try that Ultramon , thank you very much for your imput.
  6. tripwired
    tripwired Deploying Surprise in 3... 2...1...
    12 Feb 2009
