is it possible to game on my xbox 360 using multiple monitors as a single display? if so, how could i do this? i have future plans of having up to six monitors for my computer using ati's eyefinity. if i go through with that plan, i would like to be able to utilize the set-up for my 360 also. thanks. in advance. lxrysprtmscl
focusing on a 2 display configuration for the sake of simplicity. You can have 2 monitors hooked on your desktop, and have one of the monitor have your XBOX also attached to it (assuming this monitor has the connections, which does exists). All you will have to do is hit on the display change input button, to switch between (for that display) PC and XBox. Now you will have to move the windows you want to see on the other monitor while you play. No you can't make the Xbox 360 support multiple displays.
iirc Multi display can be done with Forza 2. The only draw back is you need a 360 and the game for each display you use.
