hey forum, did a quick search on the topic and couldn't find what i was looking for. here's the thing, a while ago i was running xp in "single os mode". i then got a hold of win 7 beta through school and installed. now i was running two os, one on each partition and everything was fine, at startup i got to choose which i wanted to run. when win 7 was released i got it and decided to format each partition to make a clean start (tend to do that from time to time). now, when i installed them again i only had win 7 running (started with installing xp), i didn't get to choose at startup. now a year later i figured "screw you win 7, i want xp for gaming", installed again on my d partition, and now i can't boot into win 7 . (the old installation was just lying around gathering binary dust). it's a laptop if that helps. any settings in bios (?) i need to change? doubt it since i've never had to before. been running multi os since win 2k and never experienced this before.
You'll need to boot from the Windows 7 disc and run "Startup Repair" which should put the Windows 7 bootloader back. This should pick up both installations and give you the correct boot menu to let you choose the installation to boot.
alright sounds reasonable, will try that when i get home. any thoughts on why this happened? is it a win 7/vista specific problem or just something that got messed up during installation?
You installed XP over the top of Win7, so XP wrote it's bootloader over the windows 7 one. It's an XP issue, not a Windows 7 one. Without any question I'd ditch the XP installation to be honest - is there any particular reason you're installing it for games? Any that completely don't work under Win7?
actually i installed xp over win7 once and win 7 over xp once and had the same issue. the reason is mostly that my 1 gig ram isn't enough really, having problems when playing. i'm gonna slim win 7 down as well, to see if there's a significant speed difference. forgot if i have an extra slot for ram, will check later today. edit: even the simple ones like civ 4 are a burden for my laptop. i know it's more of a gfx issue, but i didn't experience this as much when i had xp
