Networks Multi PC control software (Like VNC but not)
Discussion in 'Hardware' started by :: kna ::, 11 Jan 2004.
  1. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Ok, ages ago I used a piece of software which let you slide off the edge of your screen, as if you were using multiple desktops, but this would actually let you move over to another PC (via the network).
    i.e. PC1 Display 1 <-> PC1 Display 2 <-> PC2 Screen
    I could move the mouse all the way from PC1/D1 to PC2 Screen.
    It was freeware as well.. anyone know what it was. It's a tricky thing to search for and I only remember it because someone told me about it.
    Ta!
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Um, sounds like VNC to me...
  3. :: kna ::
    15 Mar 2001
    No, you see that's why I put 'like VNC but not' :)
    VNC allows you to control the desktop of PC2 in a window on PC1, however this software lets you 'pan' over to the Monitor of PC2 from PC1.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    Ah, that's me being muddled.
    Was it Zap who uses something like this on his work machine?
  5. RTT
    RTT #parp
    12 Mar 2001
    It was called Synergy, kna :)
  6. :: kna ::
    15 Mar 2001
    BINGO.. nice one mate. :clap:
    Off to sourceforge I go!
  7. Draxin
    Draxin Seeker of Photons
    29 Nov 2001
    only 563KB? is that right? that cant be right, for the EXEs for a windoze env.????
  8. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Do you know if this will work with OS X?
  9. Atomic
    Atomic Gerwaff
    6 May 2002
    No it wouldn't, but I'm sure there is a simular program for MAc's somewhere on the net....
  10. GrimReaper
    GrimReaper What's a Dremel?
    23 Jan 2004
    I use a remote program Called Netop very easy to use and it does what your looking for. Used in schools alot to monitor pupils untill the pupils get it lol. hope it helped
    -GrimReaper
  11. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    It uses VNC, it's called WIN2VNC.
    Just search goole.
