PSU multi sata power cabale
Discussion in 'Hardware' started by dinoscothern, 4 Nov 2017.
  1. dinoscothern
    dinoscothern Minimodder
    16 Aug 2010
    I'm trying power a number of 2.5" hard drives .
    At one end I have a Silverstone ST85F-PT.
    At the other I have 8 x 2.5" sata drives fitted in 4 x 3.5 caddies.
    The 2.5" drives are effectively recessed so multi sata cables where the daisy chain is from left to right instead of in from the top basically wont fit.
    I've tried a number of approaches with various degrees of success, but all are a bit 'meh',
    e.g.:
    2 x Silverstone CP06-E4 SATA Power Adapter Cable - too rigid cables work loose)
    4 * Akasa AK-CBPW05-30 SATA Power Splitter - bulky - some cables work loose)
    They are fine cables, but they just don't work for me in this situation.
    I've (finally) found something that might work better:
    Phobya Multi SATA power cable (4x)
    This has a molex at one end and I still have to deal with the rather long power supply cable.
    1) Has anyone seen a similar cable with a sata connector instead of the molex?
    2) Ideally I'd want one with the correct power supply connector, then I could avoid the messiness - Is this something I could get made or would it be sensible to try and make one myself?
    Best Regards
  2. dinoscothern
    16 Aug 2010
    Interesting, I can't edit the title so it will have to remain cabale instead of cable.
  3. Vault-Tec
    30 Aug 2015
  4. dinoscothern
    16 Aug 2010
  5. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
  6. dinoscothern
    16 Aug 2010
