Multimedia card protected ???
Discussion in 'Tech Support' started by Sevar, 5 Feb 2007.
  1. Sevar
    Sevar What's a Dremel?
    5 Feb 2007
    i have a multimedia card is using in my nokia handphone. i cant edit any file in my multimedia card now when i put into card reader, it prompt me a error that "The disk is write-protected Remove the write-protection or use another disk" . anyone help, thanks.
  2. DougEdey
    5 Jul 2005
    Is it an SD card? If so there may be a tab on the side which you need to flick to the other position.
