Modding Multiple LCDs
Discussion in 'Modding' started by nosmo, 20 Apr 2004.
  1. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Is it possible to run more than 1 lcd on the same computer ?
    Coukld I have 1 on serial and 1 on parallel connections ?
    Could I have 2 on a single serial or parallel connection ?
  2. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    If you want them to display the same as each other and are usuing serial you can hook them upto the same port. If you want different screens you can use as many as you have ports for my running multiple instances of your LCD software (correctly configured of course). :thumb:
  3. nosmo
    5 Oct 2003
    :jawdrop: that was fast.
    So to display different things I would need say 2 parallel ports ?
    Is there any s/w that support multiple LCDs or would I have to have 2 instances running or 2 different programs.
  4. Twitch
    Twitch What's a Dremel?
    13 Mar 2004
    You could just get adapters from parallel to usb so the limitation is just as many usb ports you have, and you could always get hubs and add on, so I see no problem with having as many was possible :D
  5. nosmo
    5 Oct 2003
    Been looking at adaptor cables but they seem expensive.
    And making your own seems too complicated for me.
    Will probaby stick to a single LCD as my 1st serious mod instead of being over ambitious :D
    Thanks anyways.
  6. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Um, why not just use TWO usb LCD's?? :eyebrow:
  7. nosmo
    5 Oct 2003
    I am on a tight budget and am looking at a cheapo £5/£10 display from fleabay to experiment with before I get deep into this modding lark :D
  8. fillip
    fillip What's a Dremel?
    9 May 2002
    I'm still waiting for an answer to the question about software :D
