Electronics Multiple LED Question
Discussion in 'Modding' started by tigermain, 25 Feb 2002.
  1. tigermain
    tigermain What's a Dremel?
    24 Mar 2001
    Hey peeps why dont this work
    12v-LED-R-LED-LED-LED-GND
    Thats the order I have coming off the psu. All the leds light individually when I apply a 3v feed. I have checked the polarity of the leds and 12v supply.
    The r = resistor (440ohms) I think (def suitable for 3v off 12v - checked)
  2. linear
    linear Minimodder
    5 Oct 2001
    Your resistor is too large.
    Each diode will drop a voltage about equal to its turn on voltage, which you don't specify. If they're blue that's probably around 3.7V, or around 2V otherwise.
    so let's assume Vd = 2V, you have them arranged in series, so you need to add the voltages. Your effective Vf is 4 * 2V = 8V.
    Then you use the usual formula:
    R = (Vs -Vf) / Id
    so assuming a typical 20 mA,
    R = (12 - 8) / 0.02 = 200 ohms.
    If they're blue, you've got effective Vf > Vs, which won't let you light any of them up.
  3. tigermain
    24 Mar 2001
    Cheers so a 200 ohm it is !
