Electronics Multiplexing Senfu/CompuNurse Probe
Discussion in 'Modding' started by koolshot, 2 Jun 2002.
  1. koolshot
    koolshot What's a Dremel?
    10 Apr 2002
    I would like to have one display and multiple probes, so that I can switch between the probes and get a reading.
    I took a close look at the flat temperature probe (thermistor?) of my probe, and it is written "103" on it.
    I would guess it to be 10*10^3=10K ohm.
    So I took out some 10K ohm NTS thermistor I have, and measured the resitivity.
    The values were a bit different.
    Original Probe - 10.3K ohm
    Thermistor 1 - 11.2K ohm
    Thermistor 2 - 11.7K ohm
    Naturally all three gave different temperature when connected to the display. Room temp was about 26 deg C.
    Anyway, I got a cup of hot water, placed all 3 probes hanging off the top of the cup (in the way of the steam).
    Original Probe - 7.xK ohm
    Thermistor 1 - 4.xK ohm (low 4K)
    Thermistor 2 - 4.xK ohm (high 4k)
    This means that the probe is not a normal thermistor? Is there some where I can buy the same probe?
    Thanks in advance.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    It's probably a "normal" thermistor, but a different Beta-value to the others. The Beta-value affects the slope of the temp/resistance curve, so the hard way is to calculate it from a few readings at different temperatures, or find some specs with resistance at two or more temps you could compare.
    Plenty of links for 102 thermistor, but mostly pdf :sigh:
    The 10k is usually at 25C, so it's a better reading than your others ;) though my Senfu is off a few degrees compared to a mercury thermometer.
