Overclocking multiplier help
Discussion in 'Tech Support' started by luker, 28 May 2011.
  1. luker
    luker What's a Dremel?
    3 Jan 2010
    ive recently got a p867 pro running with a 2500k,but when i attempt any overclock from stock to anything up to 4.8 its fine for a couple of minutes then pc slows to a crawl then cpuz says core at 800 and a x8 multiplier any ideas
  2. TaRkA DaHl
    TaRkA DaHl Modder
    15 Mar 2011
    Sounds like its maybe throttling down, speedstep would only take it down to 1.6Ghz (x16).
    What happens if you only do a 100Mhz overclock?
  3. luker
    3 Jan 2010
    i will try that and let you know
  4. luker
    3 Jan 2010
    i tried adjusting cpu max and min in power settings on windows 7 and that seemed to of solved it
