Overclocking Multiplier locked 1155 CPUs
Discussion in 'Hardware' started by noizdaemon666, 18 Apr 2012.
  1. faugusztin
    11 Aug 2008
    So let me get this straight.
    Core i5-2400 has 3.1GHz base clock, 3.4GHz max Turbo clock. Limited unlock gives you +0.4GHz in case of 1 core load, that is 3.8GHz. Then the reason i was confused is the fact that 2 and 3 core load has the same Turbo multiplier (+2) and only the 4 core load has the lowest +1 Turbo multiplier. That gives you :
    1 core load : 3.1+0.3 (Turbo)+0.4GHz(+4 multiplier)=3.8GHz
    2 core load : 3.1+0.2 (Turbo)+0.4GHz(+4 multiplier)=3.7GHz
    3 core load : 3.1+0.2 (Turbo)+0.4GHz(+4 multiplier)=3.7GHz
    4 core load : 3.1+0.1 (Turbo)+0.4GHz(+4 multiplier)=3.6GHz
    Now it starts to make sense :). The reason i didn't understand was that i thorugh you are able to set the same value for 4 core load as you have for 1 core load, but that is clearly not the case.
    I hope it also helps noizdaemon666.
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    It helps :)
    Basically if I get an i5 or i7, it will turbo (when using 4 cores) up by 1 multi and I can set another 4 multis above that. Correct?
  3. wyx087
    15 Aug 2007
    well, you can set whatever value for all cores (eg. 38 on 2400) but it will only turbo to 36.
    noiz, faugusztin got it 100% correct in my quoted post. it is +4 on all turbo values. when using 4 cores, you still go up 0.4GHz because before overclocking, it does not run at 3.7GHz (1 core does) 4 cores run at 3.2Ghz.
    noizdaemon666 likes this.
  4. mrbungle
    20 Sep 2004
    I think largely peoples perception of non-k cpu's is they are unclockable but with turbo and the multi trick along with running them at a bit higher base clock you can get most chips to run around 4ghz under most load situations.
  5. noizdaemon666
    15 Jun 2010
    AH yes, I get it now :D Cheers guys, very helpful as ever :thumb:
    Only problem now is affording an i5 :hehe:
    JBond likes this.
  6. wyx087
    15 Aug 2007
    you'd need at least a 2500 for that :(
    my 2400 run at 3.6GHz to 3.8GHz. more than fast enough, but still feel disappointing when i look at most people with their 4.5GHz overclocks.
  7. faugusztin
    11 Aug 2008
    Don't be, i run my 2600K on stock (no time for quality OC with 99.9999% stability)
  8. mrbungle
    20 Sep 2004
    Ah your multi is two down 31 instead of 33 of the 2500.
    Wouldnt worry still stupid fast.
  9. wyx087
    15 Aug 2007
    im willing to overclock, let's swap :D
