Multiplier Question
Discussion in 'Hardware' started by Irteza, 13 Apr 2004.
  1. Irteza
    Irteza Banned
    14 Mar 2004
    Hello
    i wasjust overclocking my 1700+ on a gigabyte ga7n400pro2 motherboard with some crappy 2100 ram
    is it ok if i use a low multiplier below 10
    i cant remember which 1 i used but my cpu was able to hit 210mhz fsb with the crappy ram
    so can you tell me if low multiplier is okay
    thx :D
  2. unclean
    unclean SMP obsessive
    30 Dec 2003
    yeah, that should be fine. i run my Nforce2 board at 9x multi with 229mhz FSB, is your 1700+ a DLT3C?
  3. Irteza
    Irteza Banned
    14 Mar 2004
    i think it is but i cant remember ill post abt it later on
  4. unclean
    30 Dec 2003
    ok, if its a DLT3C... theres no need to drop the multi, it should do like 2300mhz easily...
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Might need a voltage hike, me old 1700 DLT3C JUIHB wouldnt do 2.3gig on anything less than 1.8v, that was with a carp mobo though...
