A/V Music database help
Discussion in 'Hardware' started by dom_, 23 Oct 2006.
  1. dom_
    dom_ --->
    4 Jan 2004
    I have now reached a point where i have too much music and keep repeating on albums as i forget i own them. Which is most annoying.
    So what i need is a program which i can use to catalogue my LP's and CD's.
    Ideally i don't want an online based database though.
    Free would be great but i will pay if it is a good bit of software.
    Cheers :thumb:
  2. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Excel?
    I'm looking for a similar thing, but something will automatically make a list of albums/tracks I have, just in case I lose any of it.
  3. A3D
    A3D What's a Dremel?
    14 Oct 2005
  4. dom_
    dom_ --->
    4 Jan 2004
    Thanks i am trying it out at the moment. I must say it looks good so far.
    The only long term problem now is that i have to insert a few hundred CD's and manually add a few thousands LP's :(
  5. fartonmyear
    fartonmyear What's a Dremel?
    16 Jul 2004
    how can i get album art with this program
  6. dom_
    dom_ --->
    4 Jan 2004
    new -> music cd or vinyl -> artist/title search -> then search
    Or for a CD just use the CDDB2 option if you want it to get the info from an inserted CD.
  7. Will
    Will Beware the judderman...
    16 Jun 2001
    Take a look at Music Collector as well, whilst you're at it...seems to be the most popular software for such as a task, from reading the Zerogain forums :)
  8. dom_
    dom_ --->
    4 Jan 2004
    Ah yes, something i should have done more closely it seems. Cheers Will
  9. amyangel
    amyangel Banned
    8 Nov 2006
    Is it ok now?
  10. lcdguy
    lcdguy Minimodder
    25 May 2004
    Outsource it :)
    If you want a cheap solution to make custom databases like access check out the latest version of openoffice they added an access style database program allowing you to make queries, forms, tables, etc.
    I use it for cataloguing my software / movies.
