Linux Must-Have Linux Software
Discussion in 'Software' started by Hybr1d, 9 Jan 2006.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    :waah: :waah: :waah:
    It wont install the compiler or the dev files :waah: im missing out on so much software.
    I hate being a linux noob :wallbash: :wallbash:
  2. automan
    automan What's a Dremel?
    11 Jan 2006
    you already have it. it's called gcc
  3. ajack
    ajack rox
    17 Apr 2003
    No, not necessarily. There are a number of distros which don't actually come with a c/c++ compiler.
  4. automan
    11 Jan 2006
    i wasnt aware of that. i learn something everyday :)
    i'm so used to having gcc that i cant imagine it not being included with every distro.
  5. AJB2K3
    12 Dec 2005
    I chose not to install it but after the install i tryed to install it but it wont touch the rpm on the install disk.
  6. automan
    11 Jan 2006
    cant you copy the rpm from the cd to your computer using command line?
  7. ajack
    ajack rox
    17 Apr 2003
    I assume you're using SuSE, just use YaST to install it :/
  8. AJB2K3
    12 Dec 2005
    Im a mandriva user but ive got a tone of config work still to do (8 mounths after install still fixing it).
