Apple Must-Have Software for your Mac
Discussion in 'Software' started by Hex, 6 Mar 2005.
  1. semiotic
    semiotic What's a Dremel?
    27 Nov 2010
    In case it hasn't been mentioned before Caffine for MacBook/pro users to stop the screen going dim or turning off on battery
  2. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    I may have posted here already, but it's worth mentioning again
    - Aperture 3.0
    It's about all I run on my iMac.
  3. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    I'm not sure if these have already been posted, but they're new to me and crucial to EVERYONE:
    moveAddict: This is a fairly simple bit of software that enables Cut, Paste and Folder Merge commands for Finder. If you're a lifelong Mac user I daresay you'll be wondering why anyone wants those functions in the first place, but if you're a Windows user and are wondering where the hell the ability to cut and paste files went - they went here. No more opening-two-windows-for-drag-and-drop. This mimics the modern Windows system of not messing with the 'cut' file until you want to paste it - i.e., it's non-destructive, you cannot accidentally delete a file using it etc.
    Cinch: Enables Windows 7's Aero Snap feature, where dragging windows to the left, right and top of your screen will resize them to left half, right half, and fullscreen respectively.
    Both are about a fiver (though both have limited freeware versions), which is pretty pricey for such basic features, but without them I really can't get along effectively.
  4. lightly_carbonated
    lightly_carbonated What's a Dremel?
    2 Feb 2011
    Had a quick scan through and couldn't see these two.
    MacVim - A port of the Vim, an incredibly powerful text editor, to OS X. An essential part of my day to day life. I've written a thesis and several published papers and god knows how many lines of code in vim over the years.
    Size Up - A great piece of software that enables shortcuts to arrange applications on the screen. Similar to cinch (which I have never really had a look at) with the ability to set different window sizes and margins for applications.
  5. Jeseus
    Jeseus Banned
    3 Feb 2011
    vlc player
    I recommend the VLC player, I think it works better than iTunes when it comes to play videos. It's very light. :thumb:
  6. Jaybles
    Jaybles Minimodder
    12 Feb 2011
    CodeBox, Browsers and RSS
    CodeBox
    Top notch simple editor for multiple different languages.
    Using Safari at the moment will be transferring to Google Chrome when i do a format and reinstall soon.
    As far as RSS feeds go i use Gruml at the moment because i hated NetNewsWire's interface, however Gruml is a bit buggy. :/
  7. star-shell
    star-shell What's a Dremel?
    7 Mar 2011
    For those who don't know, Steam is offering Mac platform games. Though I'm not sure how many percentage games are compatible.
  8. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    I've been changing all my dock icons today, but when I came to the finder icon it gave me a lot of grief trying to figure out how to change it, so I grabbed CandyBar and LiteIcon.
    I also used TuneUp to fix thousands of badly named MP3's and Dupin to fix duplicates within iTunes.
  9. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Apologies for not reading the entire thread but could someone point me to the thread mentioned by the OP - Windows must have software?
    Edit: found
  10. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    prey - free theft app which can transmit a signal so you can pin point where it is if stolen, also can transmit an alarm
  11. petersampsons
    petersampsons What's a Dremel?
    10 Feb 2012
    Good collection of free software. I think VLC media player is must for computer users. It's simply best multi-format player.
  12. Warner0001
    Warner0001 What's a Dremel?
    20 Dec 2011
    I think you may need a high quality dvd slideshow software for your Mac like the Fantashow in my blog:http://dvdslideshow.net with 30-day free trial, which can achieve pictures, music and videos combining into one disc.
  13. farzyk
    farzyk What's a Dremel?
    18 Apr 2012
    HI. you mean general fullscreen, including laptops ?
  14. Kodongo
    Kodongo What's a Dremel?
    29 Feb 2012
    I would recommend Size Up as the most useful app on my laptop. When I switched from an Acer lappy to an MacBook Pro, I was dying for better window management. I was so accustomed to DisplayFusion and Windows AeroSnap and OS X was streets behind in this regard. Size Up has made life so much easier. This is my current layout:
    I simply choose a two button combination of Command, Option or Control with my left hand and one of the keys in the lower right hand side of the keyboard and I can manipulate windows easily to my heart's content.
    If I used a mouse with the laptop, I would also consider Cinch.
  15. chewbaccas_nan
    27 Jun 2011
    Prey is good for if your macbook gets nicked, it pin points where it is. Also Sophos anti virus is also worth downloading - just incase! :D
  16. JimmyTheTrumpet
    JimmyTheTrumpet What's a Dremel?
    7 Jun 2012
    Remote Desktop via RDP
    Couldn't get by on my mac without access to my windows servers. I used Remote Desktop Connection for Mac from Microsoft (free) at first, but now I swear by CoRD (free).
  17. JimmyTheTrumpet
    7 Jun 2012
    Programming editors
    Kod
    Still in its early stages of development, but there looks to be a lot of potential.
    TextWrangler
    My go-to programming editor, which I use every day and would be lost without. Syntax highlighting for all common languages and is very stable.
  18. CraigWatson
    CraigWatson Level Chuck Norris
    9 Apr 2009
    +1,000 to these, CoRD and TextWranger are awesome! :D
  19. lcdguy
    lcdguy Minimodder
    25 May 2004
    got my first mac last week here is what i have running on it. Some free, Some not so much.
    adium
    sophos antivirus
    Lightroom 3
    Photoshop CS5
    Filezilla
    VLC
    Burn
    Steam
    Final Cut Pro X Trial
    Adobe Premiere Pro CS6 Trial
    Crossover XI (Trial)
    Timemachine Scheduler
    macports
  20. zatanna
    zatanna What's a Dremel?
    15 Oct 2010
    if not already mentioned, techsmith stuff.
    i use jing (free & easy screen capture tool) and camtasia studio (not free, but fairly straightforward, bug-free video editing).
