Must Kill Teddy Bears - CPU Mad Reader Mod for Oct.05!!
Discussion in 'Project Logs' started by Sheldog23, 25 Mar 2005.
  1. Cabe
    Cabe What's a Dremel?
    14 May 2002
    who cares that its only april?
    Best mod of the year award, right here.
  2. the.nth.degree
    the.nth.degree What's a Dremel?
    11 Jun 2004
    very nice work. certainly brought alot of life and character to a usually plain and ugly case. just a quick thought on dispersing that white light: if possible, try frosting the back of that image. if not possible then try adding a piece of frosted acrylic/glass to the back of that panel. it should diffuse the light, spreading it evenly and give the effect yer lookin for. that's why lightbulbs are frosted.
  3. Reaps
    Reaps What's a Dremel?
    18 Aug 2004
    Very very cool and original too, which is getting harder and harder to achieve.
  4. Draeth1
    Draeth1 What's a Dremel?
    5 Jan 2004
    Awesome job. I have one question though, how come on the left hand panel you have Teddy Be rs ? Was leaving out the A intentional? Kinda sticks out to me in every picture.
  5. Sheldog23
    Sheldog23 What's a Dremel?
    11 Jan 2004
    Nope, that A must have stayed behind on the vinyl mask. It stands out to me too but most people don't notice it. I think I might route out an A there at the end. who knows.
    As far as the whitle lighting. I got that problem solved with some metal tape and placing the ccfls at the sides instead of the middle. but now one of the ccfls bumps the Acrylic drive cage. So I am going to have to route out a small channel so I can close the door on that side.
    Here are some pics of the donor case. It will be properly shot and buried in an unmarked grave after all parts have been transfered.
    note the fine craftsmanship on the PSU air intake
    and of course the "VW beetle wiring harness" inspired internals.
    We got a lot of work done and most of the pieces are in. I fixed the White lighting issue and the lighting is now beautiful. Now I just have to put the mobo and cards and clean up the wiring. Should be finished tommorow.
  6. Sheldog23
    11 Jan 2004
    OK. I got all the bezels on. Including the one attached to the DVD and the Light bus. Its getting there.
    I got a little more wiring because with all the hardware in it subdues the lighting. I really was expecting that and wanted it to some extent, but the must kill teddy bears down the right hand side of the bezel isn't lighting up. So I am going to cover it in frosted vinyl and add some blue LED's back there.
    Not to mention I tried to fire it up an my Mobo went Kaput somewhere in the transfer. So now I have to get another one. So that sucks.
    Here are some pics of where I am now. This is with all the harware in including the bad mobo.
    as you can see from this pic the MKTB down the bezel is just invisible.
    stay tuned for more...
  7. frodo
    frodo What's a Dremel?
    1 Nov 2003
    Damn man!!! that is some seriously awesome work!
    every time i see an acrylic case mod it brings me closer and closer to going up in the roof and grabbing my old one down!
    the reason i put it up there was because i didnt want to mod it (not enough confidence)
    but that was when i was 11, so you know, im 15 now, and far more confident when it comes to modding, so i might go and grab the case down later today, and do the mods ive always wanted to do to it!!!!
    i love those vinyl decals/appliques, wish i knew people who could draw/sketch/whatever that well!!! those grills are awesome aswell :D
    keep on moddin' :dremel:
  8. Sheldog23
    11 Jan 2004
    Thank you, and just curious, do you mean attic or upstairs instead of roof?
  9. frodo
    1 Nov 2003
    I meant attic yes, just most people argue when i say attic, so i said roof...
    didnt get it down today as my dad was out for the whole day, and i cant get the ladder to the attic down :S
    really... really... want to learn how to airbrush now! would love to do some custom designs
  10. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    damn that turned out real nice!!!!
  11. tsa cain
    tsa cain What's a Dremel?
    14 Mar 2005
    yeah this case looks sooo nice.
    at first i wasnt interested because its a clear case(cant stand them) But with all the stickers it looks a LOT better
  12. Sheldog23
    11 Jan 2004
    anyhoo here is the final update. I need to fix a few things I noticed in my pics but they are minor. So here we go.
    Not much difference on this side. New MSI mobo and you can see the Zalman Cooler with its blue LED fan. Lights are toned down a bit more. Though you can't really tell in night shot mode.
    Here you can see the MKTB along the bezels is now lit blue. Along with how the drive is Stealthed. I love the writing on the wall. 8)
    Detail on the drive stealthing. I cut of the screw heads and glued them to the Bezel. This way when it is closed it looks screwed in and matches the rest of em.
    here you see the Blue MKTB alond the side better. Also finally chaged ther front fan to Red.
    I put in a mini ATX board because he just doesn't use all the PCI slots. Plus the bottom two have the light swithes in it anyway. I added this piece of Acrylic with carbon fibre look vinyl to cover the empty space and to keep the red glare from shining through to the artwork on the back.
    I didn't get to clean up the wiring and mod the inside as much as I wanted too. It is all out of site for the most part. I just thought it would be cool to do some Defyant style wiring. In fact there were a lot of things I would have done to this had it been mine. Brandon was going through some serious Comp withdrawal though so I felt bad and let him take it home and play with it. Maybe he will be inspired by these forums and work on it some more.
  13. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    Wow, that's a great looking mod! Very professional indeed. I know it was a lot of work, and you did it as a project, but that kind of talent could easily earn you a paycheck doing custom work.
    Any plans for your next adventure?
  14. Sheldog23
    11 Jan 2004
    Someone suggested I do a Quake2 mod similar to this. It kinda sounds fun, But no plans for a new mod yet. I need to hurry up and make something to show off at quakecon. :sigh:
  15. spacehopper
    spacehopper What's a Dremel?
    23 Dec 2003
    gorgeous....
    a truly amazing mod! :rock:
  16. DeadTeddy
    DeadTeddy What's a Dremel?
    22 Apr 2004
    amazing, just amazing!
  17. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    The case looks really adorable.
  18. Snowshadow
    Snowshadow What's a Dremel?
    15 Aug 2003
    Excellent show of teamwork and artwork on both your friends and your part. You both show a LOT of tallent! :thumb:
  19. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    x2 on that.. very nice! :hip:
  20. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    very nice looking case. its certainly an interesting use of a acrylic case, but one which definatly works. the mixture of white, red and blue lighting really goes well with the style of drawing.
