ever since i started using this mouse iv been getting what seems to be low fps in certain areas, tho the fps reading is 40-50fps. mainly happens when the gfx card has alot to render. have ppl seen this issue iv only been playing MoH so iv not noticed it in other games
New one on me. If you are talking about slow mouse movement then try disabling the pointer acceleration. I did this and it solved some issues I was having in that area.
disabling pointer acceleration helps, also make sure "auto smooth mouse movements" or the like isnt on, that overpolls the mouse. last, make sure you have the latest Logitech drivers for your mouse installed. Logitech is notorious for shipping products with extremely old driver disks, although the MX1000 is pretty new..i would still check anyway
