Modding My 16-mod eeePC documentation
Discussion in 'Modding' started by Langer, 21 Mar 2008.
  1. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Do your fingers cramp when you do these things? Laptop repair always makes my fingers hurt. And nice job on the touch screen.
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    I'd say the pressure of the situation gets to me more... I laugh inside when I can feel myself beginning to sweat during intensely tricky connections.
  3. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    how much weight did all the modifications add?
    effect on battery life?
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    I get about 1.5-1.75hrs with everything on and running loaded @ 1035mhz w/ 60% fan, but I'll never run all the devices at once.
    On average I'd estimate about 2.5hrs.
    As for weight... it's an inconsequential amount, but you've got me curious now. I have an unmodded eeePC arriving next week, I'm modding for a customer, I'll compare the weight differences for you then.
    I purchased a 20,000mah 74wh external laptop battery on eBay.
    It outputs the usual 12/16/19 volts which means that I had to get a car charger to step down the 12v to 9.6v. It also has a 5v USB port for charging phones and cameras and the swarm of USB powered products out there today.
    It was a little pricy at $119.89 USD delivered but it works great; gives me about 4hrs(loaded @ 1080mhz)-7hrs(idle @ 1080mhz) on it's own, with the factory battery removed all together.
  5. Langer
    Langer Jesse Lang
    24 Jan 2004
    Eating of the forbidden fruit,
    I got a new ProMac yesterday.
    Overwhelmed with excitement I had to announce my jump to the darkside.
    With the Mac comes pics of my workstation.
  6. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    :eeek::jawdrop: Dude! What have you done?!
    :( (you) (turn cold sholder) :grr: (Me)
    Just kidding bro. :D:hehe:
    I used to dream of having a Mac because they had sooo much raw power. That was until I realized that you don't have to buy a Dell or HP (for example) retail from the shop. No. There is actually a whole community out there that build them sooo much cheaper! Apple rip you off IMO. I just checked there NZ site and for every 2GB of DDR2 800MHz RAM you add NZD$830. With the Mac Pro holing up to 32GB of RAM, that's a total of over NZD$15,000 (because at 32GB they use 8x4GB RAM modules) just for the RAM!!! I can buy a 4GB stick for NZD$200!!! How exactly can they justify it?
  7. Langer
    Langer Jesse Lang
    24 Jan 2004
    They have this.
  8. casey_cole
    casey_cole What's a Dremel?
    16 Dec 2006
    Love the mods Langer. I'm seriously considering grabbing me an Eee PC as a "grab-and-go" laptop, so seeing your mods has helped me think.
    CC
  9. TazzY
    TazzY Honda POWER
    17 Jul 2008
    Need some help here
    Thanks and cheers!:lol:
  10. twentynine
    twentynine Can never win...
    6 Jun 2008
    Good sir you are something else. That is just simply impressive. Period.
  11. Langer
    Langer Jesse Lang
    24 Jan 2004
    @Tazzy - I posted in your thread
    @twentynine - Thanks mate, I appreciate the kind words.
  12. airchie
    airchie What's a Dremel?
    22 Mar 2005
    Niiiice.
    Have you seen any higher-res 7" screens available anywhere?
    The only thing holding me back from modding my eeePC is the crappy res on the screen. :(
  13. Langer
    Langer Jesse Lang
    24 Jan 2004
    The screen is capable of running 1024x768 (and better yet, 1000x600).
    Here is a video I made of my eeePC swapping resolutions on the on-board LCD.
    On that note, I usually run mine on an external screen running 1280x1024.
    The eeePC 900 series has a 9" LCD that runs 1024x768 natively.
    If you're interested in eeePC mods, I suggest checking out eeeUser.com - here is my thread.
  14. mattthegamer463
    26 Nov 2004
    Its hardly the same as having a real res 1000x600 screen though. I only very sparingly ran it in those non-native resolutions. Work has been done putting a 900 screen in a 701, and while it works, a BIOS modification is required to get it working properly and nobody has been able to do it yet. Not to mention the physical mods required to fit the screen.
  15. Krikkit
    21 Jan 2003
    Those are some awesome mods on there mate. Seriously good work. :D
  16. Langer
    Langer Jesse Lang
    24 Jan 2004
    True, but it works in a pinch. And at 1024x768 the screen isn't very legible.
    And a big thanks to all the supporters!
  17. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    My postage scale says my 701 weighs exactly 2 pounds.
    You using that Mac as a space heater? The dual 2.5Ghz G5 I have sitting in the rack down in my garage has an inlet temp of 86F and a back side temp of 119F. Though both processors are maxed out running folding at home.
  18. Langer
    Langer Jesse Lang
    24 Jan 2004
    2x22" 2x19" 1x46"
  19. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    consider spinning the 22in screens around so they portrait style next to the 46in. i think they would line up nice that way.
    maybe mount the 19in screen side by side above the 46in
  20. Langer
    Langer Jesse Lang
    24 Jan 2004
    I was thinking something very similar.
    If anyone else is interested in eeePC mods, I documented this one as well - yet another eeepc mod
