Hi everybody! Here you are some pics of my first simple mod (newbie style ) This is the averall view of my mod: This is the circuit (sorry 4 bad pic): This is the front, without the case: Just a piece of "that one with little holes for circuits" which I painted black with a special spray color for Warhammer soldiers, color is "Chaos Black" and fixed it to the bone of the case thanks to those holes in the metal. I soldered (is that correct?) all the leds a the right height to touch the front panel. the round white led is a separate circuit that substitutes the power led... This is how I modified the floppy drive cover FRONT and BACK: Just made a rectangural hole and glued with Loctite a rectangular portion of plexiglass ("fumé") 5mm thick. I alos have a .mov of the running circuit but it's 4megs... I can upload it if you want. ciao, jack. ps. sory but I dont know english electronics words
good first mod how did u cut the floppy bay cover? it looks very straight and has curved lookign corners
Hehe... too much time on your hands while scanning for viruses? I know the problem... I do... Not bad for a first mod man!
4 554 Yeah I know it's amazig, i really couldnt believe how easy it is to cut that kind of plastic. it is quite resistant and you can make very clean works on it. Since I dont know english names 4 the tools I have used here you are the pic: (obviously I first made a hole with a drill to start) 4 RAMeLaiR XTRALOL! No, I just ran antivirus to take the pic of max hdd activity. 4 ChillingSP Really? so u speak italian?
Thats some nice work What have you got planned to do next seeing as though this is the project log section
