Planning My 2nd Core i7 PC by ./^\.ACE./^\.
Discussion in 'Modding' started by ./^\.Ace./^\., 17 Jan 2010.
  1. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    Hello everyone!
    I have built one intel Core i7 PC for my dad already and I posted it here a while ago, but now it is time for my PC to enter the spotlight.
    I need an overhaul of my work area; that means my PC, printer, monitor, you know stuff like that. So I spent over $3000 and made a computer that was just right for me.:rock:
    The specks:
    CPU: intel Core i7 920 D0 (stock, but I have had it up to 3.8GHz)
    Mother Board: ASUS P6T
    RAM: OCZ Reaper DDR3 1866Mz 6GB (3x2GB)
    Video Cards: 2x BFG GeForce GTX 295 (Quad SLI)
    Power Supply: Antec TPQ-1000
    Case: Cooler Master HAF 932
    CPU Cooler: Cooler Master V8
    You might have noticed that all of that is already in my sig but I think it is more formal to write it here.
    I did actualy build it over a month ago but I thought I should post it now because I remember that I was going to.:duh:
  2. ./^\.Ace./^\.
    7 Jun 2007
    After I got all of the new parts on my old Lian-Li PC-60 mother board I learned that the Video cards were not going to fit in the case, they were just to long.
    Well I got a modular Power Supply but does it really matter if you use every plug?
  3. ./^\.Ace./^\.
    7 Jun 2007
    Here is the 3D Mark Vantage score with stock settings.
  4. andrew8200m
    andrew8200m Modder
    4 May 2009
    Looks good mate. A little bit of an OC and you should get similar to this..
    Need any help with an OC just ask as my system is very similar to yours.
    Andy
  5. ./^\.Ace./^\.
    7 Jun 2007
    sure that would be nice, could you put your specs up?
  6. andrew8200m
    andrew8200m Modder
    4 May 2009
    i7 920 @ 4.7ghz
    12gb OCZ reaper 1866mhz @ 1880mhz cl9
    P6TD Deluxe
    2x Asus gtx295
    2x intel X25M 80gb raid0
    1x samsung F1 1TB
    Silverstone SST-ST1200 Psu.
    Blu-ray drive
    Custom watercooling
    Andy
  7. ./^\.Ace./^\.
    7 Jun 2007
    This is with my i7 @ 3.6GHz.
    CPU Temp: 83, 84, 78, 78.
