Cooling My Athlon64 Waterblock!
Discussion in 'Hardware' started by Ferrari, 6 Oct 2003.
  1. ModCanada
    ModCanada What's a Dremel?
    24 Sep 2003
    Yeah but do any of Cathar's blocks work on Athlon 64?
  2. Sin22
    Sin22 What's a Dremel?
    20 Sep 2003
    Little River products
    Click on Ordering and Pricing and there is an option for a AUD$18 A64 conversion plate.
    Add to that I direct you to this Procooling thread.
    To be perfectly honest Ferrari your answers show a slight lacking in knowledge of waterblock design. Especially with respect to the flow of water and its tendancies.
    There are several threads over in procooling, some of which include CFD analysis which I've put up on dimples and other forms of waterblock "turbulence" creators, it may benefit you to go have a look and understand Fluid Dynamics more than Thermodynamics. For in a waterblock, it is more of the fluid dynamics side of the equation that determines the effectiveness of a block, not the thermodynamics.
    Its good to see others making blocks, its always greatly encouraged dont get me wrong, but it takes a strong man to be able to accept criticisim and mistakes which are pointed out to him.
    Most of of the issues with ur block stem from the choice of material aluminum which MUST be anondised if you wish to sell it. The sealing of the block besides just a metal seal. Over time that will leak. And the basic fluid dynamics within the block which will cool a IHS CPU relatively well, but the understanding behind why it does so seems flawed.
  3. Brennan
    Brennan What's a Dremel?
    27 Apr 2003
    Hey dudes, I think you're making too much of a big deal about this. I mean, look, ferrari went through a bunch of work desinging and having his own waterblock made, and even if he doesn't understand some of the stuff he's talking about his block doesn't look that bad.
    I don't think he copied off cathar or anything, it sounds like he just set out to make a waterblock that will perform well and now he wants to sell it, what's the big deal? So what if he tried to sound cool or something, he's just supporting his work.
    Good job on making a decent looking A64 block ferrari :thumb:
  4. Haddy
    Haddy World Domination
    22 Jan 2002
    man go away for a few weeks and ive got 50billion posts to reed through....
    decent looking block but new judge a book by its cover...When will we see some offical tests with the processor it was designed for considering the t-bird test didnt exactly blow my mind considering most koolance systems will do that well....
    as for all the keyboard tough guys out there settle down...thats my job ;) :p
  5. Pug
    Pug What's a Heatsink?
    16 May 2002
    :idea: /*me hits 8-BALL with a Model M while Haddy's busy* (for old times' sake) :D
    j/k, Welcome back buddy. :thumb:
  6. Haddy
    22 Jan 2002
    no net for two weeks makes haddy a very cranky toughguy :p
    Anybody herd anything else about any new blocks for the athlon64
  7. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    me takes beating for old times' sake.
    what is a model M anyway.
    8-ball
  8. Pug
    16 May 2002
    Ouch!
    [/OT]
  9. MikeTitan
    MikeTitan Ling Ling: 273 Battle Points
    4 Mar 2003
    While Im not a genius in cooling this statement would almost certainly make me worried about purchasing said product
    Besides that I would also like to see some sort of o ring or extra leak protection. The copperbase would also be nice, and instead of aluminum maybe plexi? I like they way it looks but It looks to be that it might leak..
  10. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    The get out claws is pretty standard stuff really.........you will find most companies use one.
    However your other concern about the lack of gasket does set the alarm bells ringing and I find the use of locktite to create a permanent bond between the two metal a bit of a make-shift fix.
    Having said that, if this issue was addressed and more extensive testing done it would be good to see this block reviewed by independent reviewers!
  11. BadOldMan
    BadOldMan What's a Dremel?
    15 Oct 2003
    /me hands 8-Ball a box of bandages and one "free Ambo ride" card for his trip to the emergency room.................... :waah:
  12. Ferrari
    Ferrari What's a Dremel?
    23 Sep 2002
    Update!
    Ok i got some Cu bottoms here is a pix
    You also mentioned Plexy tops. Well I had my machinist make up some tops out of polycarbonate. I only have the pix he sent me but ill update you when I have them in my possession.
    [​IMG] [​IMG]
    I dont think they are finished yet but you get the idea!
  13. Theo
    Theo What's a Dremel?
    12 Jun 2003
    Broken links over here, chap..
  14. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
  15. Risky
    Risky Modder
    10 Sep 2001
    He's linking to http://69.139.9.86:83/ferrari/MY ROXOR BLOCK/R0X0RBLOCK/Cu/P0007601.jpg
    I think its the Port 83 is the problem, and I have no idea why he is using it as it. Tbh, if can't manage to host pics competently he's goin to have trouble trying to sell a product. Oh and before anyone says I should look at my firewall settings, I really don't plan to for this!
  16. Tim S
    Tim S OG
    8 Nov 2001
    I can see the pics, looks nice :)
  17. olv
    olv he's so bright
    23 Sep 2002
    yeh i can see the pics fine. wouldn't want to run water throught that copper/aluminium mix though.
  18. Tim S
    Tim S OG
    8 Nov 2001
    by the looks, it's only running through aluminium, the copper is just added to the base, I don't know whether that would be efficient or not.
  19. Nexxo
    23 Oct 2001
    Again, people make too much of this mixed metals business. A car cooling circuit mixes a lot of metals. But do you see car mechanics worry about that? Nope, just a good corrosion inhibitor (e.g. Zerex Racing) will do nicely.
  20. Ferrari
    23 Sep 2002
    Sory bigZ but the Cu was NOT just added to the Al base. That is a solid Cu base.
