Cooling My Cascade - Homemade Waterblock
Discussion in 'Hardware' started by CHECK-IT, 16 Feb 2005.
  1. CHECK-IT
    CHECK-IT What's a Dremel?
    18 Apr 2004
  2. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    It looks very nice. Well done :)
    I don't quite understand the graph though since the axes aren't labelled :duh:
  3. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    WOW very nice, looks like u bought it
    but i agree with SteveyG...
  4. CHECK-IT
    18 Apr 2004
    this is C/W. Hmm.. C/w its unit the individual the denominative efficiency of resumption / the rendition of warmth. It important it is we possess this what radiators. Its Core Temperature - Water Temperature / Power of heater
    for example: Processor temperature-40C, Water Temperature-17C, Power of heater-100Watt =
    (40-17)/100=23/100 = 0,23 C/W ;]
    Im glad, that you pleases :)
  5. Firehed
    15 Feb 2004
    Looks very well made, but I'd think it would be more effective with channels rather than just the little hole things so you could get a higher flow rate in the block. In fact, probably the best looking homegrown block I've ever seen. Looks like it performs well by the graph too :)
  6. user0001
    user0001 What's a Dremel?
    8 Sep 2004
    Looks good. What are the white pieces made out of? You want turbulence in the block for max performance so I think it might be better with more pegs and pegs that are part of the block (one-piece bottom). :thumb:
  7. Risky
    Risky Modder
    10 Sep 2001
    Looks great there :clap: :clap:
    What thread and thittings are you using there? And do you have and pictures/ details of the rest of the setup?
  8. <A88>
    <A88> Trust the Computer
    10 Jan 2004
    Very good quality, looks a professional block :) Any guide on how you made it?
    <A88>
  9. CHECK-IT
    18 Apr 2004
    Instruction will be soon probably on jet-pc.com, Quantity jets and cups is optimum. Larger quantity would spoil flow. Cascade is designed to amd with small core.
