Cooling my chiller
Discussion in 'Hardware' started by needmorstuff, 23 Jul 2006.
  1. needmorstuff
    needmorstuff What's a Dremel?
    23 Jan 2004
  2. LVMike
    LVMike What's a Dremel?
    11 Aug 2004
    why not insulate the tubes and you water tank and crank it down to 5C or 2C just add more antifreeze to the water and you should be cood to go. I dont really see the point of keeping the water at 20C, when you could go lower with that set up.
    Except of course condensation..........
  3. LVMike
    11 Aug 2004
    The set up is really nice looking, I assume that is stays out side then? what compressor and gas charge did you use? and what pump is that?
  4. needmorstuff
    23 Jan 2004
    Yip it stays outside
    Compressor Tecumseh 1/3hp 12cc
    Evap: Coaxal HX 8' long
    Controller: Ranco O16
    Condensor: From old Ice machine, big though with custom shroud
    Fans: 2 Papst typ9956
    Gas: R22
    Captube: 5 feet 5 inches 0.031
    It is a 1/3hp compressor with an 8' coaxial (tube in tube) heat exchanger for the water.
    The res is a 10l insulated drinks container. The chiller, intake and exhaust fans on the box and pump are all started with a swiftech relay kit (the 2nd rev one with 50amp inrush) with my pc. I drilled 3 x 22mm holes through my study wall and put 3 15mm copper tubes through, 2 for water one for 240v and the 12v feed for the relay.
    The relay and junction box is in the double socket in the box outside.
    The pump is an iwaki wmd30rz (30' head - pressure pump) no introduction needed :)
    It is an all year project and will keep same temp regardless of time of year - it will just need to work harder in summer. With regards to how it compares to normal water... it holds steady temps - cpu chipset mosfets and gpu all at about 30. It is outside so my study is quiet and cool. Don't know what else you would like me to compare?
    It is capable of holding 400 watts (resistor load so more in real world) at very low temps maybe sub zero, but i set at +20c so i do not have to insualte and it isn't on all the time.
    System consists of
    dfi sli-dr
    opty 170 @ 2.9ghz
    2ghz mushkin redline @ 275 3-3-2-8
    x1900 (if it get's repaired)
    apogee - ek nf4 rev 1.1 - mips mosfet cooler - ek x1900 block
    cost
    res £26
    pump £60 (2nd hand but new - $250 new)
    chiller ? (not willing to disclose price - if you want one speak to johann)
    relay £20
    quick release coulings £20
    blocks etc. £200 ish
    garden box £30
    new jeans for wife £200
  5. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Do you find the quick release couplings restricitve?
  6. needmorstuff
    23 Jan 2004
    no m8 - nor the 90 degree barbs on the mosfet cooler... haven't measured flow but the flow into the res was like a tap..
    the pump is a beast though.
  7. LVMike
    11 Aug 2004
    Yah we use two of those pumps on a medical film proccessor and they are scary powerful. I like it, really clean and well built. Good Job
  8. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    that is seriously cool (no pun-intended), very tidy looking as well. i've always thought about having a setup like this for when my computers at home and then having a portable external radiator, res and pump unit (ala koolance Exos 2) if i wan to take my comp anywhere.
    Nice work!
  9. needmorstuff
    23 Jan 2004
    cheers guys.. it's been a bit of a long one,. couple of months in the planning with a few hiccups but it's all good now. Study is earily quite and nice and cool, used to be like a sweat box with my previous water cooled system.
    Will be much neater internally when i get my x1900 back :) (if it works :dremel: )
  10. K.I.T.T.
    1 Jan 2005
    would it be possible to have a few more pics of the unit itself and also how does one go about contacting johann
  11. needmorstuff
    23 Jan 2004
  12. K.I.T.T.
    1 Jan 2005
    wow, his units are impressive. how loud is the unit he made for you?
  13. needmorstuff
    23 Jan 2004
    2x120mm fans at full pelt and a compressor... difficult to quantify a db rating tbh. Let's just say I wouldn't want to be in the same room but i am very sensitive to any noise.
    tis why i wanted it outside.
    say 45db????
  14. K.I.T.T.
    1 Jan 2005
    so kinda like a fridge freezer running full whack with a desktop fan on as well, thats not to bad tbh....now i'm stuck between getting one and using it to cool my servers or have a reasonably powerful one like yours built and use it to cool my main rig....i bet it'd be having fun try to keep the water cool in the current weather
  15. needmorstuff
    23 Jan 2004
    speak with johann m8 - but i bet he could build you one to cope with the thermal output of all your stuff. Just tell him what you have and he will do the rest...
    one big water loop to cool main rig and servers......
  16. LVMike
    11 Aug 2004
    your temps will be great in the winter..... what is your water mix?
  17. K.I.T.T.
    1 Jan 2005
    yeah, i'll do that....thanks for your help it has been most useful
  18. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    You should get some of those ultra high loud fans. Since it is outside. They run like 190 vfm a piece iono the noise.
  19. K.I.T.T.
    1 Jan 2005
    you mean the delta fans, true they do flow silly amounts of air and are very loud but whats the point if those papst ones are doing the job your not going to gain much more performance by seriously cooling the condenser, as long as it doesn't get too hot (i don't know what temps are safe).
  20. needmorstuff
    23 Jan 2004
    i do need to do something as it was so hot today that the compressor wouldnt start unless i opened the box.. maybe another fan in and out for the box and a big vent..
    dont get me wrong it runs like a dream.. just my box needs sorting.
    good news persivore has fixed my borked x1900 so should have that plumbed in by the weekend!! top guy.
