my dragon project in progres (ICE HOLE MOD)
Discussion in 'Project Logs' started by Qbank, 30 Aug 2002.
  1. Cyberbob:-)
    Cyberbob:-) Minimodder
    16 Jun 2002
    Qbank you are at it again!!!!:eeek:
    I was thinking abouthing doing some mods with Aluminium....
    But it looks to much like hard work..:confused:
    Can't wait to see the pics.... You never know it might get me off my butt to do mine....
    Just about to get a second cathode for mine, Not sure what colour to go for?? Also just getting the bits together for my fanbus. also getting 2 more antec leded fans...
    Happy modding dude........:idea:
  2. Qbank
    Qbank What's a Dremel?
    19 Jun 2002
    AVGS ICE HOLE MOD
    key got the ice hole thingy you all know it and i'm gona put an enermax on it so i was thinking an enermax has a fan speed control so way the hell do i need it on the avgs ice hole ..... :eyebrow: :idea: leds mod it .... bring on more leds :hip:
    so this is how it was be4
    to much green and not in of bleu
    so this is wat i made
    (old vs new)
    i hear you thinking were are the resistors wel gone conect the plug top the switch thingy i'm making and the resitors wil be there .. but you'le see later (when its finiched ... the switchboard he :lol: )
    so this is the red mode (tham camera focus FOCUS :wallbash: )
    thats better:D
    ohh.... thats so bleu
    and know bouth of them togetter
    neat he
    okey so wats in there where there are origanaly leds i put 3 bleu 5mm leds
    then behaind them i put 3 red highluminants 3mm leds and than 2 red highluminants 5 mm leds on the sides
    hope you like it
  3. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    that looks right nice... and thanks for figuring out your camera! :D sweet work dood. Looking forward to finding out where that diamond aluminum is going... :rock:
  4. Qbank
    19 Jun 2002
    nex week i'm gone cut it some more then bend a few pices and then goto find out where the f**** i can polich it :D its got to be shiny and than its gone go evry where :naughty:
    evry (poseble) paice of bare metal wil be coverd and a front switch module wil be mada also out of the material
  5. ::Dawg::
    ::Dawg:: What's a Dremel?
    14 Mar 2002
    im lost.. what is that ice thing a mah jig and what is your virus tube thing
  6. Qbank
    19 Jun 2002
    the ice thingy is an 60 to 80 mm adaptor so i can put an enermax on my 2100+
    the virus tube is an home made thingy that gets frech air directly in front of the cpu fan
    plus it looks wiked:naughty:
  7. essjaytee
    essjaytee emtarkanderundergunderson
    11 Jun 2002
    nice job, really creative. I'm sure if I'd had tried I would buggered it up - the ice hole. sorry You know what they say about opinions and ice holes... okay, I'm done
    hope I don't sound like right ice hole. oh, I kill me.
  8. bAnTAi
    bAnTAi What's a Dremel?
    19 May 2002
    can you get those prism stealths on their own? and where?
  9. Qbank
    19 Jun 2002
    1 st of all yes the prisms tou can get on there own where evry where they sell the prism case i got them at www.colorcase.be
    second to fit them you have to do some alterations to the case (i had to make a litle slit with the dremel so they klikt nicly
    then second the my enermax has finley araved them took long to get here so i put my ice hole and enerma in these are a few quick shots
    sory for the blur ive got a hp 812 and next wensday hp is gone bring mi a new one (the focus is all mesed up:wallbash: ) so the BRING le a new one :clap: :naughty:
    o jes the pics well here they are
  10. Qbank
    19 Jun 2002
    after a whole lot of trayng i got these
    [​IMG] [​IMG] [​IMG]
  11. Reaper_Unreal
    Reaper_Unreal What's a Dremel?
    16 Apr 2002
    That is so amazingly cool, it makes everything look so bright! Is it plugged into your HD activity or something? Otherwise how do you control the different colours? Also, about the RF mod, how did you get the power to the thing while it's off? I can only find a 3.3v line, not a 12v line that's always on.
  12. War-Rasta
    War-Rasta What's a Dremel?
    22 May 2002
    Dog, love ur Virus Tube!!
    cool idea and seems like it could really make a difference in the temp (does it make any?).
    looks like an air bazooka or something like that.
  13. bAnTAi
    19 May 2002
    I cant find them there ore at any site (its probably the fact that its 3am and i am too tired to go get some caffine....:wallbash:).....could you give me a direct link? Much appreciated.....
  14. Qbank
    19 Jun 2002
  15. banished
    banished Necromodder
    6 May 2002
    Just a suggestion: trace out the lettering and whatnot of your virus tube with glow-in-the-dark paint, then get a small UV (led or two) in there. I think that would add to the virus appeal. :cooldude:
  16. Qbank
    19 Jun 2002
    LCD
    school takes so much time my alluminium is stil not poliched but i orderd this baby
    at the end of the week i'm sepose to have it
    o jes and also
    I broke mi bleu cold cathode now i have new one with a acrilic tube round it it came with a invertor for 2 CC and a switch and a molex
    but with al this things are gone change mi temp read out has got to go.... :( due to lak of space
    in the floppy bay moust come the switches for the fans, leds and cc ...
    i stil wont to use the temp readout but i don't now where ....
  17. Qbank
    19 Jun 2002
    I know i've been silent for a long time
    I know i've been silent for a long time due to varius problems
    -Cash
    -Time
    -LDVD you peaple don't now wa that stands for
    but its " liefdes verdriet" and thats the same as being hard brokin over a girl
    But you know you get over that ****
    So were do I stand with the dragon
    wel goit some troubles
    firtsi don't have inouf bays
    i got the lis but i cand read it if it is standing in the bay so there wil be a new lcd project i was thingkin of an external scsi box or so
    secon ive got to much wire in the case stil traying to figure that one out
    third the aluminium plating is stil not in the case
    :sigh:
    And ive drawn a scematic of al the electronics neded to switch the fans and lighting , and it wil be complicated :)
    The barton that i wanted to bay performes a bit lower than i have expected so i'm waiting on the 3200+ and also fort the price to drop ...
    i'm thinking of loosing the baycovers and baying aluminium ones from coolermaster or from lian li
    I need a new cd-r mines a bit slow :grr:
    so wat good has happend
    wel after waiting 1/2 year my door arived from germanie
    and i finalie got my tv card working
    I have to sut the usb 2.0 suport down and than my hauppage works :(
    and i've updated my site a bit :)
    so go and see here
    btw i'nm begining to feel a bit stupid with my dragon project i've seen some nice things here with dragons and i'm feeling a bit low now :lol:
  18. Qbank
    19 Jun 2002
    dahm forgot the pics here they are
    hope you like :)
  19. Qbank
    19 Jun 2002
    Yess I'm stil alive ...
    I know its been a wille and yes the dragon also stil is up and running
    Whats difrent
    now AMD Sempron 3000+ 2000Mhz L2: 512KB FSB: 333 BARTON CORE
    on a a7v333 I know kniow its old but when i first came here it was the bom :rolleyes:
    Got me a PWM controler for my fans.
    With led fans and also other fans its better to use a PWM controler (Puls Wide Modulation).
    Becouse the fan gets ether 0V or 12V so it switches the fan of and on and so fast you don't notise but the speed wil decrese.
    But you're consumation of power wil also decrese, this is saffer for the leds.
    and i put in a The Zalman CNPS7000B-Cu LED
    Its big (Fan: 92mm). Its Full Copper (Weight: 755g). Its Blue Ledded. And Its Sillent...
    also got more power ... so now it has a LC6550GP V2.0 GREEN POWER
    550W, 140 mm fan
    and yes I care about global warming to ... way i don't have the mony to by water cooling for the pc and if the eart keeps warming up how the F*** am i gone cool my pc than :hehe:
    SO the power suply is a
    GREEN POWER-Technologie
    - fewer than 1W in Standby-Modus
    - 85% more efficientie
    3,3V: 35A
    5V: 40A
    12V1: 16A
    12V2: 18A
    then i got
    an extra bar of corsair so now its 1 gig of ram and it got a extra hard drive ....
    the hard drive meant there was nu room for the virus tube so ...
    but its not scrapt ... one of the reasons i'm back is i got a new project lined up bit of old parts combined with nice new once becouse lets face it ive been out for a while but the case mod stuf you can bay these days is unbeleveble ...
    :thumb:
    the raison i was absent was that I have a passion for customizing ****
    I tuned up my pc
    I even thid my mobile phone in the past (you should have seen it i think i could have puled over cars whit that phone so many bleu leds so bright :hip: ... who cares about battery life :naughty: )
    And than and stil ... Cars (one, he ...)
    so a lot of time and mony went in my car (for those of you who are remotly intrestid ...
    My Car
    and ofcourse My girl and my job also take time away
    but there is gone come a new smal project also lot of my old ones have been trached .... but update on the new project wil come and maybe the dragon chapter is long but closed ...
    so this is how the dragon stands today ....
    as you can see I know can take desent pictures :clap:
    know i also alrady could use ure help
    1 my logitech navigator keyboard broke ...
    I'm looking for somthing cool to replace it sugestions ?
    also the temp meter in de 3.5" bay broke and there is know a hole that needs filling any body got a cool sugestion ?
    once more I apoligese for my English
    first its late
    second its bin a while that i typed the langeuge
    third .... I forgot the third :duh:
    so i'm of to bed hopping to see some reaction and hits tips sugestions ... tommorow ...(its onley a day away .... :p )
  20. Qbank
    19 Jun 2002
    no sugestions for a new keyboard and wat to put in my 3,5" bay
