Cases My dream case :)
Discussion in 'Hardware' started by MarkW7, 25 Mar 2009.
  1. Elton
    23 Jan 2009
    I like the 300, In fact I have it, it's a great case, although it does lack space for cards with the PCI-E 6-pin in the back(HD4850..>_<). It has a great cooling solution and coupled with some home made fan filters, a 6000RPM Intake(or exhaust if you decide to replace the pre-installed rear exhaust fan) fan and some soundproofing mesh, it owns.
    However Since I have lacked the diligence to create my own window, I cannot see my own parts, Oh well, I like it's understated Looks nonetheless.
  2. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Those big fans produce a ridiculously low pressure due to their low spinning speed.
  3. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Will do, i think it's going to take 3 weeks for the fan to arrive from america so it'll give me 3 weeks to look for a case :)
  4. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    I don't understand what this means?
  5. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    I'm fairly sure that means it won't push air through confined spaces very well (e.g., heatsinks), but as it's a case fan, I don't think it matters.
  6. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Ah, It'll be an exhaust - im sure it'll be fine even if its just for show :D
  7. Wiremaster
    Wiremaster Folding Fanatic
    6 Mar 2009
    How about this? I mean, it's two fans, not one, but they're bloo and the front is simple. I don't know the brand very well, but when I read this thread I immediately thought of this case.
  8. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    That looks nice!
    But newnegg don't ship to the UK?
  9. mm vr
    18 Nov 2007
  10. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    The 360mm Fan arrived today.
  11. g-freak
    g-freak New Member
    25 May 2006
    speaking of fans...
    All this talk about fans on the side of cases reminded me of these pics i got from a friend a few years ago, 2003 to be exact.
    This fan, and a second one, were pulled working from a data-center that was being shutdown, or so i was told.
    The fan is an AMCO BTA10, normally used for data-center cooling.
    10" dia.
    3.5" deep (260mm x 90mm)
    540 CFM
    direct AC current
    Google tells me that this an "alternative" to the above part, the specs are very close to what i remember.
    http://www.rselectronics.com/Catalog/ViewPart.aspx?Part=OA254AP-11-1WB&MFG=ORI
    Thought someone might appreciate it and/or find it amusing.
    P.S. please pardon me if this is a thread-jack.
  12. pimonserry
    20 Dec 2008
    >500 CFM is just ridiculous. There's no way you could exhaust that much air intake (unless the big fan was set as exhaust, in which case there's no way all the rest of the fans could intake that much ;) Might as well leave the fan slots without fans, probably easier!)
    Hence, you know you want it ;)
    I bet it makes a ****load of noise though :(
  13. Elton
    23 Jan 2009
    I Currently use a 6000RPM 120mm Fan, louder than anything else in my computer but it has about 180+ CFM.
  14. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    That PC would be tempted to take off.
    Any more thought other than the Antec 300?
  15. pimonserry
    20 Dec 2008
    Antec 300 is good and cheap, with good airflow. What's not to like?
    Although, if your budget's expanded, a whole new level of options appear ;)
    E.g., Antec 1200 (larger, more airflow)
    Other Antec premium models
    Cooler Master premium models (IMO their cheap models aren't worth it)
    And more..
