Modding My dynamic lighting system - *PICS* - comments please
Discussion in 'Modding' started by Mark R, 29 May 2002.
  1. Mark R
    Mark R What's a Dremel?
    29 May 2002
    Some of you may already have seen this device, but I'm looking for comments - and also interest: I have enough spare parts for a few of these, although I am reluctant to build them myself - I am happy to sell self-assemble kits.
    Variable colour illumination thanks to red, green and blue LEDs. Multiple extreme brightness LEDs, produce light output approaching that of a luxeon star, but in a lower profile package, and without the need for heatsinking.
    Microprocessor control of the LEDs allows easy selection of a particular colour, or fading colour sequence.
    Anyway, enough text - I'm sure you want pictures - so here they are
  2. WhyPush
    WhyPush What's a Dremel?
    22 Apr 2002
    I'd like to build one. Let me know how you'd like to handle it from here, but have to make sure to tell you, I'm in hte US so it might be easier to just get info from you and buy the parts myself.
    Am I right that it'll cost about £20 for the LEDs? (8*2+4*1)
  3. Guest-16
    Guest-16 Guest
    write a review on how to make em m8! looks great, 16million colours of l33tness :D
  4. brutal
    brutal What's a Dremel?
    7 Nov 2001
    that is very very cool.
    i would love something like that butwith blue, white, and UV :)
    *adding to future projects list*
  5. Phire
    Phire Performance-PCs.com
    11 Jan 2002
    leds are teh wave of teh future :D
    nice work bro!
    psss--do white !
  6. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    hrmm have you any schematics he asks? :)
    -scoob8000
  7. Daneo
    Daneo What's a Dremel?
    11 Feb 2002
    neato
    does it get annoying? i would think the constant change would get on my nerves.
  8. Mark R
    29 May 2002
    Whypush: The circuit is quite straight-forward, and if you are reasonably competent I see no reason why you couldn't build it yourself, from parts sourced in the US.
    I will have to supply the CPU, as it needs to have the firmware flashed before it will do anything useful. The firmware still has a few bugs, and there are a few new features which are waiting to be finished - so it's likely to be a few weeks before I'd be happy to sell a programmed chip.
    I also suspect that you'll find it easiest if I supply the LEDs - you wouldn't believe how difficult it was to get these - you also won't believe how big the minimum order was (as I had to buy direct from the manufacturer's distributer).
    Note that it is important to use the right LEDs for this - the conventional shape 'super-bright', 'hyper-bright' etc. LEDs, have a very narrow beam, meaning that the colours mix very badly, and you end up with a spot light rather than even illumination. These super-flux LEDs are also so much brighter as to be laughable.
    Scoob8000: I'll draw some schematics up in a couple of days - but as noted earlier, you need a custom programmed CPU.
  9. linear
    linear Minimodder
    5 Oct 2001
  10. WhyPush
    22 Apr 2002
    Through that link it's going to run $24, and I'm sure shipping would be less within the US. It'll be interesting to figure out what the whole unit will cost. to build.
    And I wish I could type...
  11. brutal
    7 Nov 2001
    Im very interested in this technology for a few differant projects.
    I found this at lumileds, bottom of page 2 http://www.lumileds.com/pdfs/SuperFlux_ds.pdf:
    Selection Guide
    Part Number LED Color Total flux V(mlm) @70 mA Typ. Total Included angle @90 .
    HPWA-MH00-00000 AS AlInGaP Red-Orange 1500 95
    HPWA-DH00-00000 75
    HPWT-RD00-00000 44 X 88
    HPWT-MD00-00000 TS AlInGaP Red 3500 100
    HPWT-DD00-00000 70
    HPWT-BD00-00000 50
    HPWT-RH00-00000 44 X 88
    HPWT-MH00-00000 TS AlInGaP Red-Orange 4200 100
    HPWT-DH00-00000 70
    HPWT-BH00-00000 50
    HPWT-RL00-00000 44 X 88
    HPWT-ML00-00000 TS AlInGaP Amber 1700 100
    HPWT-DL00-00000 70
    HPWT-BL00-00000 50
    HPWN-MB00-00000 InGaN Blue 2000 110
    HPWN-MC00-00000 InGaN Cyan 5000 110
    HPWN-MG00-00000 InGaN Green 4500 110
    HPWN-MW00-00000 InGaN White 4000 110
    This is a pretty good selection of color, even tho no UV. Could do some cool stuff with white when working in your case so you have decent lighting
  12. Mark R
    29 May 2002
    Good grief - that must be a new addition. That certainly wasn't there a fortnight ago. :)
  13. ChriX
    ChriX ^
    30 Aug 2001
    That Sir, Is elite. ;)
    The colour change is great, usually you can never get leds bright enough to do that, nice job :)
  14. brianpodskalny
    brianpodskalny ladies night!
    3 Nov 2001
    i would be interested in ordering a kit if it was made avaible. very nice effect.
