News My Favourite Firefox Addons
Discussion in 'Article Discussion' started by CardJoe, 9 Feb 2010.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    Xmarks is my must-have
    Video DownloadHelper is also another that i cant live without.
    there are a few others, adblock/noscript, greasemonkey, and WOT also help
  3. Xir
    Xir Modder
    26 Apr 2006
    Bit of an oxymoron if you ask me :D
    Good, wouldn't want anybody to have a tough time looking for them.
    Seiously, you caved in and use the preset folders?
  4. Combatus
    16 Feb 2009
    Was thinking more about organisation than knowing where to find them and no, I have different folders, just thought it was easier to get my point across ;)
  5. Orionche
    Orionche Guest
    Was looking for a Multirow-type addon for ages. :| Cheers for posting that...
  6. oMonarca
    oMonarca Elitist Brick
    15 Dec 2009
    +1 for Xmarks!
    Down Them All is also pretty good. Simple Boss Key too >_>
  7. Krikkit
    21 Jan 2003
    Xmarks, FireSomething (for lols), Firesizer, IEView (for those pesky sites that still don't work), and oldbar. :D
  8. yuusou
    yuusou Multimodder
    5 Nov 2006
    xmarks, adblock plus, downthemall, firegestures, autohide statusbar and auto menubar.
    Also multiproxy switch and create an SSH tunnel to home for use at work ;)
  9. scawp
    scawp What's a Dremel?
    8 Sep 2009
    Opera created speed dial not Chrome
    teamtd11 likes this.
  10. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    you forgot ad block plus
  11. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    I can't live without Smoothwheel makes scrolling so much nicer. I use chrome at home but am still stuck with FF at work due to all my dev tools.
  12. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Would that make him a bad person? What's wrong with using the preset folders?
  13. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I use Snaplinks (or Multi Links) - they both allow you to draw a box round a bunch of links and open in tabs, both have their advantages.
    Xmarks for password sync mainly, thinking about changing to Weave for the tabs sync - when it existed Google Browser Sync was good for that.
    Distrust - a bit like the In Private mode but I can keep all my currently open tabs open - really helpful - and for while it is turned on, your history works as usual
    Close n forget - had a Stumble Upon site you don't want in your history? Click the button and it all goes away.
    I have changed my Awesomebar to be on the same row as all the menus to save space, I cannot get enough!
  14. proxymoron
    proxymoron What's a Dremel?
    20 Mar 2009
    What Scawp said - Speed Dial was in Opera way, way, before any of the other browsers chose to copy it.
  15. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Awesome add-on, but I doubt they "forgot it". After all, they rely on advertising on the site. Then posting about an ad-removal add-on would be foolish.
    On topic- I.E.Tab (which I assume is similar to krikkits IEview mentioned above) is an absolute must have. It even works with some (shockingly old and poor) website's i use that for work that "only" work on IE6.
  16. Spiny
    Spiny What's a Dremel?
    6 Sep 2006
    In order of favouritism:
    downthemall
    xmarks
    1-click youtube downloader
    url shrink easy
    foxyproxy
    add to search bar
    adblock plus
  17. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    NoScript Cheesecake.
  18. knuck
    knuck Hate your face
    25 Jan 2002
    nice list, nice thread
    looks like I have stuff to test :)
    my input:
    -download statusbar (much more convenient than the default download window)
    -mixtabplus (i use it to put my tabs at the bottom of firefox)
    -the rest were named already :)
    edit: wow lastpass is impressive ! Hhighly recommended to anyone who was hesitating to try it. Give it a shot, you won't regret it
  19. phuzz
    phuzz This is a title
    28 May 2004
    in the order I install when faced with a new install:
    Adblock Plus (seriously, how can anyone use the web without this?)
    XMarks (sync your book marks between desktop and laptop, bonus points for allowing you to have slightly different bookmarks at home and work)
    Gmail Notifier (because I can't be arse to keep checking my inbox)
    Download them All (allows some changes in your download folder, but also handy for downloading all 20 pictures on a particular page etc.)
    FxIF (displays EXIF in the image properties)
    Popup Alt (gives you the IE mouse over text)
  20. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    Xmarks for me, very good!
    The uTorrent thing is interesting. Have you looked in to the 'WebGUI' that utorrent offers? It allows you to control Utorrent through your browser on another PC in the LAN. You can copy a link location and just paste it in there and it will download it for you. Also useful to check on status or pause the download when you want to game at night (Downloads at night on my schedule). Also means you can access it on any PC.
Tags: Add Tags
