Modding My first build .
Discussion in 'Modding' started by seebul, 12 Sep 2005.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    Hi, not sure if this is really the right place to put this but here goes anyway...
    I just thought i would put up a few pics of my first erm.... mod - if u can call it tht. Its the first pc i have built and i am only fourteen so plz be nice? Anyway as my first build i am quite proud of it, and it is very quick :D
  2. lstopper
    lstopper What's a Dremel?
    17 Aug 2005
    nice looking case (pre modded i guess) but whats the big switch hanging down inside for ?
  3. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Looks like a CCFL switch to me, mount it somewhere and the mod'll be complete :thumb:
  4. seebul
    seebul Minimodder
    9 Aug 2005
    thnx. oh yeh tht.... oops. It's a switch for a cathode inside but is very dodgy if it touches anyfin metal the whole pc just switches off, so i have it hangin there till i have an idea of wot to do for it. :dremel:
  5. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    Mount it on the front, and solder then heatshrink instead of using crimp terminals.
    Also You might want to tidy up those cables...presentation is key and zip ties are your FRIEND!!
    Nice case though, lot's of potential and welcome to Bit-Tech.
  6. seebul
    seebul Minimodder
    9 Aug 2005
    thnx alot m8, i am just about to order some cable sleevig off the net for it, hopefully that should clear it up a bit. :D
    Also i was just wonderin whether anyone had any ideas that i could do for this case to make it look abit nicer and cooler?
  7. theurgy
    8 Oct 2004
  8. X_VADER_X
    X_VADER_X What's a Dremel?
    7 Sep 2005
    Nice case...
  9. seebul
    seebul Minimodder
    9 Aug 2005
    yeh i like wot tht guy has done to his, bit to much work for me tho i fear! :D
  10. theurgy
    8 Oct 2004
    Don't worry...you'll addiction will grow.
  11. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    yeah i read through the thread real quick and noticed some stuff was said about your wire managemnt!
    Well... I concur good luck sleeving and be careful! i get most of my battle scars from cable sleeving more then cutting metal?!
  12. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    lol nice to see I'm not the only one :hehe:
  13. seebul
    seebul Minimodder
    9 Aug 2005
    i got some cable sleeving off the net but i am stuck. Do i have to take every pin out of the main power plug that goes to the motherboard? how do i get the sleeving round it?
  14. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    horrible wiring :)
  15. LoneArchon
    LoneArchon What's a Dremel?
    15 Jun 2004
    to do it right and make it look nice yes.
  16. keir
    keir S p i t F i r e
    5 Oct 2003
    What does it do? lol
  17. mattthegamer463
    26 Nov 2004
    its been said before, fix that wiring! it looks terrible! other than that i like it.
  18. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    not bad, post pics after the wirings been done
  19. X_VADER_X
    7 Sep 2005
    I am trying to make my own PC and maybe just mod it to death but one problem... I am a 14 year old freshman highschool student with No job so I am saving up alot of money till I get a job... but once i get a PC i have many projects in the future for it...
