Scratch Build – In Progress MY FIRST CASEMOD!
Discussion in 'Project Logs' started by patte41, 3 Mar 2012.
  1. patte41
    patte41 What's a Dremel?
    12 Sep 2011
    hey Bit-Tech..
    i got an idea for a long time now, and the day i will make my first mod is finally here!
    pictures!! http://www.octeamdenmark.com/forums/worklogs/8650-mit-foerste-casemod-6.html#post84415
    -first i would like to thanks my sponsors
    [​IMG] and [​IMG]
    and i would like to say that i´m 15 years old ;)
    i´m sorry i was a littel late whit the pictures ;)
    here we go!
    -this is the plan.
    - all the pipes are cut, and i had made all the weldings
    -and here are a overlock.
  2. patte41
    12 Sep 2011
    hey again :D
    now i have made a more precis draw of the project
    - the ligth blue is "see through" and the darker area can´t you see through. the 4 holes is to my fans, and i the oblique area in the front, there will be a fan controller and a on/ off switch.
  3. patte41
    12 Sep 2011
    im back!
    now i have got my hardware to the mod.
    ^^ not the noiceblock, i have brought another controller
  4. patte41
    12 Sep 2011
    hey..
    i got an idear for the fan mounting, before i don´t want a big mess of screws at the outside of my case so i made this
    and then i made it!
    i think it will be good ?
  5. patte41
    12 Sep 2011
    today i had made some more..
    first i would like to thanks CUDS over on http://www.octeamdenmark.com he had made the plexiglass fore me.
    - i have to make a 45 degres cut on the side and how do we do this?? i asked my dad and he came whit this
    the solution was´nt so gut, but i forgot to take a picture of the other one... sorry
    - how it will bee
    -45 degrees cut
    http://www.octeamdenmark.com/forums/attachments/worklogs/4953d1330799532-mit-foerste-casemod-imag0217.jpg
    - one of the sides of the case was 4 mm longer then the other, so i have to cut it and weld it agen, and here is the welding
  6. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    awesome :) how the hell did you manage to get sponsorship on your fiirst mod!? :eek:
  7. patte41
    12 Sep 2011
    i don´t know, i just think i was lucky :D:D
  8. Reconnec7ed
    Reconnec7ed What's a Dremel?
    29 Feb 2012
    Lovely lightweight case there :p
