Modding My first casemod
Discussion in 'Modding' started by The Modder, 30 Nov 2004.
  1. The Modder
    The Modder What's a Dremel?
    30 Nov 2004
    this is my very first and sucsesfull casemod
    i replaced the old and ugly fangrill whit an exiting one..
    i used my "dremel" to cut out the grill.
    here is some pictures:
    the ugly one:
    the new one:
    so what do u think of my first casemod?
  2. adamjones01101
    adamjones01101 What's a Dremel?
    29 Jul 2004
    Looks good...Welcome to the forums! Hope the rest of your mod goes just as well as this did. What are you planning to do with the rest of your rig? Let us know, maybe we can give you some tips! :thumb: :D :dremel:
  3. The Modder
    30 Nov 2004
    well...i already made a new mod...ive stealthed my dvd drive:p
    here is some pics... i used double layerd tape..and some ductape.
    as you maybe can see...is the switch over my fanrheoubus....the switch is going to be used for my cold chatodes
  4. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    Ah, the wonders of duct tape. And when you cut out your existing fan grill, you did remove the components of your pc. That is a must, i do suspect mobo's would not like tiny filings of metal. Just my two cents worth. And well done, it looks like it is a mod well done.
  5. The Modder
    30 Nov 2004
    thank you...and about the cutting of the fangrill....no..i didnt do it whit components inside since the grill was on the side panel of the tower...so i just pulled the panel out from the rails..and started cutting:p
