Build Advice My first Extreme Build
Discussion in 'Hardware' started by voids sleet, 21 Nov 2011.
  1. Guest-44432
    Guest-44432 Guest
    Running a tri SLI setup, I would only use watercooling, due to the heat and the space between each card. Otherwise the top card runs hot, the middle runs extremely hot and the bottom one would run cooler than the other 2, all depending on space in your case from the bottom card to the bottom of your case.
    If you don't, you will have one hell of a noisy case (Hairdyer territory!!).
    (If only people really knew what it's really like to be running an extreme setup, and the true costs involved...)
  2. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Apparently the X79 VRMs run rather hot, with the reduced airflow resulting from having watercooling rather than a huge fansink on the Processor; That could make a fair difference.
    Hence my suggestion that the VRM's be Watercooled as well.
    HDD's are happy so long as they've got some airflow. I read somewhere the 30 degrees is prime operating temps for a Hard-drive. Memory only really needs a bit of airflow too, unless you're running 1.65V 2133+mhz stuff overclocked to the point of madness.
    So primarily, the key things you should be looking at getting under water are: GPUs, CPU, and VRM circuitry.
    True_Gamer's PC is a prime example. He's got everything hooked into a Phobya 1080 Rad (At last check, might be a different brand, but it still carries 9x120mm fans.) and it all runs remarkably cool. Even though it's all overclocked to the point some people would start considering Ln2.
  3. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    what are your specs for your system out of interest due to the comment above
  4. Guest-44432
    Guest-44432 Guest
    i7 990X @ 5.02Ghz EK HF waterblock | Gigabyte X58 UD7 + Ek Chipset, Vrm waterblock | 12GB G.Skill Trident 2Ghz 9 9 9 24 | 120GB Vertex 3 | 2x 64GB C300 in Raid 0 | Intel X25 M Gen2 160GB SSD | 2x 1TB Samsung F3 | 3x Zotac GTX 580 EK waterblocks 960/1940/2200 | Creative Titanium pro 7.1 | Logitech X530 5.1 Speakers | Silverstone ST1500W PSU | Silverstone TJ07B | 1080 radiator for GPU's & CPU | 240 radiator for motherboard chipset/VRM
  5. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    OMG what's the total price on that? You going to add a snazzy new monitor/s to that?
    Sent from Bittech Android app
  6. Ljs
    Ljs Modder
    4 Sep 2009
    Hah - He seems to change displays every other month!
    Been through 6 x IPS monitors and a 60" TV since about March.
    I'm waiting for the 3 x u3011 setup. ;)
  7. j4mi3
    28 Jun 2011
    i cant imagine a better display setup. someone out there has it! it would look insane in portrait mode
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    My advice, watch what True gamer does and do that...
    He always owns a dream machine...
