Modding my first mod... half anyways
Discussion in 'Modding' started by s7e7e7n, 25 Jul 2002.
  1. s7e7e7n
    s7e7e7n What's a Dremel?
    10 Jul 2002
    yeah i know i cheated.. premod... well im a newbe.. do i get a break.. well i made my on baybus.. slight prob... i messed it up... i made it a series ,, power wire to first switch, then from that switch to the next.. not parelle(sp).. anyone got a layout of how to set on up like that... i have to have the first switch on in order for any of the others to work... and the led always stays on.. any ideas.. did i mess up.. anyways.. here are some mod pics... not much
    stealth cd/rw bay..
    and h.r. giger. prints under the plexi... blue lights.. and clear blue led fan...
    http://members.tripod.com/se7ens_ss/computerpics.htm
  2. s7e7e7n
    10 Jul 2002
    [​IMG][​IMG] [​IMG]
  3. VadimtheConqueror
    VadimtheConqueror I love the little tacos...
    10 Jul 2002
    i like the Giger pics on the front, those are sweet.
  4. s7e7e7n
    10 Jul 2002
    i found you can use the little rubber button like things you put on the bottom of things to keep from scratching your table or what not.. radio shack has these clear ones that are about a 1/4 or a little less thick with a sticky side.. works great for mounting on the back of the bay cover ..for hitting the eject button....
  5. s7e7e7n
    10 Jul 2002
    comments ??? sorry.. my first time.. just looking for imput. i want to put another giger pic on the baybus also... on this case... the bay covers and case are a tight fit.. i need to trim a little around the cd bay cover.. it sticks from time to time... whats the easist way to get some activity lights on the cd/rw...
  6. mc909
    mc909 What's a Dremel?
    18 Jul 2002
    I really like those giger pics...how'd you do that, man?
  7. Yoda
    Yoda What's a Dremel?
    26 Jun 2002
    Looks good(for a premod). Did you put the graphics on the front?
    I would leave the wire thing of the floppy though the idea behind a stealth is to hide the existance and make it look clean. That would kind of defeat the purpose.:cooldude:
    Try to think of something to change on that bax so you can say you did it.
