Modding My first mod!
Discussion in 'Modding' started by Ph4ZeD, 14 Apr 2010.
  1. DRC™
    DRC™ What's a Dremel?
    14 Mar 2010
    Very nice :D
  2. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I'm not sure mate, presumably gloss is a harder finish to obtain for a rookie?
  3. stonedsurd
    11 Mar 2009
    It's not a question of rookie or not. It's just a bit of work with the prep and the sanding and all that.
  4. bulldogjeff
    2 Mar 2010
    I have to say i really like the red on that, it really pops, have to say looking good so far
  5. merple
    merple What's a Dremel?
    18 Dec 2007
    Nice work.
    It just so happens that I also have a Cosmos S and plan on painting it with Halfords paint :D
    Mind telling me how much primer and paint you have used?
  6. Ph4ZeD
    22 Jul 2009
    @Stonedsurd - One of the things that worries me is that the motherboard tray is riveted and thus non-removable, making sanding the inside of the case difficult >< I do however have a spare Antec 900 that could serve as a home for my rig while I work on my Cosmos.
    @Bulldog - Thanks for the kind words! I had never really sanded or painted anything in my life before, so I'm proud of my results :)
    @Merple - I bought 1x 300ml can of red primer and 1x 300ml can of red paint - I used Honda Red paint (Halfords obviously sell car paint but it works just as good). I completely used all the paint can when finishing the side panel, and the primer can feels pretty empty too. So I used all of both cans for this job.
  7. Danny
    Danny What's a Dremel?
    4 May 2010
    Love red, that's my favorite color combination. It's looking very nice and well done on your first mod! :D
  8. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    Gloss is not that hard to get a nice finish. as said before get the prep work done then wet and dry in between coats to get the smooth finish.
    as for the motherboard tray, drill out the pot rivets then paint it all then pot rivet it back together.
    case is looking good though mate nice work.
  9. merple
    18 Dec 2007
    Thanks for the info ph4zed, I have some Ford paint picked out. Looks like I'll be needing quite a few cans to do insides and side panels.
    Is red primer specifically for red paint? I've only really seen the grey kind being used.
  10. bruce_rob
    18 Apr 2010
    you can get white primer, i would say use white or grey but it depends on what colour your planning on using
  11. Ph4ZeD
    22 Jul 2009
    I got the red primer simply because it was the same price as the white :) If you were using red primer and wanted to paint something white, you'd obviously need more coats for the same result due to the colours, whereas red paint over red primer is a doddle :)
  12. bruce_rob
    18 Apr 2010
    that's it mate i have always used white primer my self, its up to you what you go for mate and its all trial and error
  13. merple
    18 Dec 2007
    Just popped up to Halfords earlier and the sticker on the paints I wanted said to use grey primer :thumb: just a couple more things to order and I can take apart my cosmos :D
  14. Ph4ZeD
    22 Jul 2009
    What colours you gonna use mate?
  15. merple
    18 Dec 2007
    picked up some matt black and ford purple velvet :)
  16. Ph4ZeD
    22 Jul 2009
    Going to be posting updates soon as I get home from work!
  17. Ph4ZeD
    22 Jul 2009
    Painted the first top handle :)
  18. shah
    shah Minimodder
    29 Jan 2010
    Good stuff mate, now you need to get the black colour done so get a complete look.
  19. Ternix
    Ternix What's a Dremel?
    5 Nov 2009
    Very nice, I agree once it's black it shall look great. Keep it up.
    PS are these PC's living in a workshop, looks very dusty :D
  20. Ph4ZeD
    22 Jul 2009
    I'm debating starting a Project Log for this mod as I'm continuing my work on the case and I don't think this is the best place for continuing the photos of my progress. Any thoughts?
