Overclocking my first overclock
Discussion in 'Hardware' started by zairs, 8 Jan 2012.
  1. zairs
    zairs What's a Dremel?
    30 Nov 2010
    been doing an overclock on my 470gtx and would like your advice on whether it ok to use
    my settings are
    core voltage - 1000
    core clock - 795
    shader - 1590
    mem clock - 1674
    was using auto fan which only went up to 69%
    the temp went up to 91c max when running heaven
    i am gonna move onto the cpu after
  2. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    775 core, 1500 shader is where I'd take the card to. Should keep temps down in the 70s which is much better and it won't be much slower than your current OC. Maybe 2fps.
  3. zairs
    30 Nov 2010
    just changed it too
    774 core, 1548 shader (cant seem to unlink the two slider bars on afterrburner)
    temp was at 75/76c
    would this now be a good every day setting, also would it be worth me fitting an aftermarket cooler to push it a bit harder and keep temps down??
  4. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    That would depend on the cooler. If you squeezed an Arctic Cooling triple-fan heatsink on there with a good application of TIM: you should see a fair reduction in temps, dependant on the airflow through your case.
  5. zairs
    30 Nov 2010
    my case is all about air flow:)
  6. LennyRhys
    LennyRhys Oink!
    16 May 2011
    When I had my GTX470 I used
    1087mV
    865MHz core
    1730MHz shader
    1928MHz memory
    That's the best that I could get but it was freaking insanely fast :D
  7. zairs
    30 Nov 2010
    is that was you used everyday?? what sort of temps were you getting??
  8. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    75C is about right for those clocks. A good aftermarket cooler might be a good investment if you want to push it even further.
    And quit bragging LennyRhys :D. My PSU can't handle those settings, it just cuts out :Waah:
  9. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Hahah :D
    I used to get 75-80C load temps but I had the Palit GTX470 which has a very good heatpipe cooler. Like most graphics cards the cooler is shrouded with plastic, and when I removed the shroud and used a 120mm fan on the heatsink, load temps dropped by 10-15C. :thumb:
