My First Project Log!! WOOT!!
Discussion in 'Project Logs' started by MrShake, 13 Nov 2003.
  1. Fyberwire
    Fyberwire What's a Dremel?
    14 Sep 2003
    Those sparks off the dremel were intense. I'd cut my case just to get a pic of that :D :dremel:
    Good work, especially for a first mod!
  2. DizBjOhN104
    DizBjOhN104 What's a Dremel?
    3 Nov 2003
    nice case man, looks like the dremel did a lot of good work for ur window, i should get me one
  3. MrShake
    MrShake What's a Dremel?
    3 Nov 2003
    **Update** New Cooling, Updated Larry LED, and Bezel MOD!
    Heres a nice chunk of update.
    In this update:
    Coolermaster Aero 7+ Added
    Modification to the original Larry Lazer LED
    Front Bezel/Light Bay Bus
    New Cooling:
    Theres the old cooling (stock AMD)
    Theres the New Cooling
    And there it is in place.
    With my 2500+ barton stock speed with the stock cooler, I was at about 42-43 at idle.
    With the new cooling, and the barton OCd to 3200+ speeds (200FSB x 11), I am running idle at about 36, 42-43 at stress.
    I'm happy!!!
    Larry Lazer LED modification:
    Velcro!! Its hard to move or remove anything thats double stick taped, so here it is!!!
    Bezel Mod/Light Bus:
    The good from Radio Shack
    The switches, moded for the spade connectors and heat shrinked.
    There it is in place, its raised off the bezel by nuts and bolts about a half an inch, looks sweet!!
    And there it is with the Bloo glowey goodness!!!
    Theres that update!! comments please!!!
  4. MrShake
    3 Nov 2003
    One more quick update:
    I saw something similar to this somewhere and I marvled at
    the simplicity of it, so I tried it, and WOW has it cleared up my wiring!!!
    Simple Fan Bus:
    Theres the money shot of the goods from radio shack
    theres the stuff needed for the fanbus!
    Theres the complete fanbus!
    (please shoot me a line if you have any questions about it)
    (I will try to find the original and give credit!!)
    Theres the fanbus in place, its held in with self-taping fan screws into one of the empty 5 1/4 bays.
    Behind the MB tray Before:
    Behind the MB Tray After:
    And there you go, This project will be on hold for a while, untill Its time to update hardware, and put in the water cooling... I will let you know if I do anyting!!!
    Thanks for reading!!
  5. ATi Loyalist
    ATi Loyalist Who throws a shoe?!
    9 Nov 2003
    nice mods man, the screws on the front glowy thing are a little too long in my opinion, but thats just me, (my 0.02 cents)
  6. MrShake
    3 Nov 2003
    they were further out, but its easily adjustable.. I'm gonna live with it for now and see what I think after a bit!
  7. MrShake
    3 Nov 2003
    *bump*
  8. sickskater6911
    sickskater6911 What's a Dremel?
    9 Oct 2003
    That is niiiiiiice....i am lovin it....(Badabababa....im lovin it*mc'y d's*)
    did u frost the edges of ur window....i love that....im gonna do that to mine.(hope u dont mind)
  9. MrShake
    3 Nov 2003
    hehe.. I just bumped it so my dad could see it easier.. but hey, more responses.. yea. I frosted it with krylon glass frosting paint.. just do like 3 light coats and not just 1 thick coat, and it gones on clear, so its kinda decpetive!!
    And go ahead and frost away, no bigie!!
  10. sickskater6911
    9 Oct 2003
    i was thinking just taking sand paper to it....i wasnt aware they made frosting paint.....wjere do i get it...home depot?>
    if u have AIM sign on now
    my sn: SickSkater6911
