Modding My first real mod
Discussion in 'Modding' started by eeced, 25 Jul 2009.
  1. eeced
    eeced My finger is in the fan
    26 Mar 2007
    After I finished a small paintjob on my girlfriends computer she asked me to mod a case to two brothers (9 & 11 years old). Which was fine except I've never modded a case and the budget I had to work with was €23.
    So no new hardware could be bought, an old IBM APTIVA case was used and the window was taken from an old discarded bookcase. The only thing I spent money on was sandpaper, primer, paint and putty (filler or whatever it's called):rolleyes:.
    Since my girlfriend went on holiday to her parents and took the camera with her I had to use my phonecamera which isn't the greatest there is (actually it's nowhere near). So the projectlog was never put up here, but I thought I'd show the result anyway.
    I'm currently planning a higher budget casemod and I've already got the theme selected, just have to get some parts to build it with. :worried:
    docodine likes this.
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    That is damn cool! Huge difference, and can't tell it was that old case! I especially like how you made the keyboard match. I would love to see a full worklog from ya in the future! Good luck and keep on modding!
  3. stonedsurd
    11 Mar 2009
    GREAT job :thumb:
    I've a whole list of OEM cases I'd like to get my grubby paws on :naughty:
  4. docodine
    docodine killed a guy once
    10 Feb 2007
    Wow, that's a very green case. :thumb:
  5. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    lol yeah, thats a very green case :p it looks good, any progress pics?
  6. sentek
    sentek What's a Dremel?
    5 Jul 2009
    wow, really nice :thumb:
    i love the colour :D
  7. capnPedro
    11 Apr 2007
    Way to go! That's excellent for a first mod, and I respect that you went "all out" rather than just doing something little!
  8. anubis1126
    anubis1126 Modder newbie but not for long
    25 Jun 2009
    That is awsome such a huge difference for virtually no outlay awsome
  9. eeced
    26 Mar 2007
    Thanks for all the positive feedback :)
    I put quite some effort into the case since I wanted them to have something that wouldn't look too much like the old Aptiva case which is quite ugly if I may say so.
    I'm aware that the colour is quite unusual but it sure makes the case noticable. :p
  10. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Very nice, great job!
  11. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Good job, a nice green, the keyboard looks great!
    Regards
    GiGo
  12. shazza
    shazza What's a Dremel?
    24 Nov 2007
    Very well done! Did you add the window as well?
    Looks like you did a pro job on the keyboard also.
  13. eeced
    26 Mar 2007
    Yes the window was added by me.
    The keyboard was a real pain to paint, each key had to be removed seperately and the put back the same way. Had to use another keyboard for reference when I put them all back, never seen a keyboard designed that way before (but then again, I don't open every keyboard I come across).
  14. mod job
    mod job never leave unsupervised
    16 May 2009
    great job on a shoe string budget . nice colour scheme
  15. Bonzo45
    Bonzo45 Ex CPC
    25 Apr 2009
    Are you sure that's the same case as it started out?!?!? Looks nice! How'd you do the fan vent in the front of the PC?
    Bonzo
  16. eeced
    26 Mar 2007
    As mentioned I had a very tight budget so I had to make use of whatever I had lying around, the front hole I used a spindle-case.
    Since some of the pics were quite because of the camera bad I'll just put up a few of them.
    Front removed and put on table, all buttons etc was removed.
    Started building up the new front with the filler (correct word?).
    After some sanding I thought that a front hole for the fan would be nice, I came up with ideas for the case as I went along (which I'll never do again).
    I used a drill(!) to cut out the hole and then sanded it down smooth. Here I've glued the spindle to the front and testing if it fits correctly when the front is attached to the rest of the case.
    Some more filling to do...
    Not done yet but very close to finished, some edges needed some finetuning with the sandpaper.
  17. Loom
    Loom What's a Dremel?
    10 Aug 2008
    Good job!
  18. N!ck
    N!ck ModMag.Net
    24 Sep 2008
    nice!
