Cooling My First Watercooling Loop. - with pics
Discussion in 'Hardware' started by AlexB, 17 Nov 2006.
  1. AlexB
    AlexB Web Nerd and WC Addict
    22 Dec 2005
    .. By Alex Ball, Aged 23 and a half.
    Well, last night was my first nerve-wracking night - I got in from work, and started fitting the new kit.
    Took the computer apart, and fitted the waterblocks to the mobo, and graphics card
    Then fitted all the pipework.
    It's a very tight fit. I'm sure the loop is no way near perfect, and I've probably made a load of school boy errors.
    The loop:
    Pump > CPU > GFX > 120.3 Rad > Chipset > 120.1 Rad > Res
    I'm not massively happy with the layout, and it may get changed. I quite fancy a bigger case to do it in, as I'm sure I could make a neater job of it! I really dont like where I've had to put the pump, for instance.
    Still, the pump has been running since late last night, and there are no leaks so far - nothing is plugged in, but I'm still hoping that it wont leak while I'm at work today.. :$
    I'll report back with the performance figures later tonight.. see if its made a difference from the stock cooling and Big Typhoon.
    Thanks to Frodo for sorting the kit out. - and Thanks to Highland3r for the advice last night!
    Any thoughts/concerns? (..and be kind, I'm still very much a newbie to watercooling!)
    Here's a link to a few more pics of the setup:
    http://www.dorkish.com/index.php?a=albums/Personal/Watercooling/
    Please ignore the messy wires - they will be tidied away before long ;)
    -al.
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Nice one mat, glad you got it up and running ok :D
    One thing which might help with tubing neatness is running the far left rad straight after the far right one in the loop. Might allow you to route tubing a little better perhaps.
    Maybe try Pump -> CPU -> GFX -> NB -> Rad1 -> Rad2 -> Res?
  3. airchie
    airchie What's a Dremel?
    22 Mar 2005
    For best cooling I think you should run
    pump > rad1 > CPU > NB > rad2 > GPU > res.
    That way, the water is at it's coolest when going to the CPU and GFX blocks giving the best cooling. :)
    Or, you could run the rads in parallel for even better cooling.
    Running them in parallel means the coolant is in the rads for longer and hence gets cooled better.
  4. AlexB
    22 Dec 2005
    Cheers lads - I might have a re-think later then and see what I can come up with.
  5. Krikkit
    21 Jan 2003
    Not really - the water would pass through 2 rads before it gets to the CPU, then sit in the res for a while with Highland3r's setup. That'll probably give the best CPU temps, as the water's at a minimum temperature there.
    With the current loop it's exactly the same as yours, but the pump and rad are in different places. No difference between the two, and no real difference in temps either tbh, the average water temp will still be the same, and let's face it - the northbridge temps don't matter a great deal as long as they're reasonably stable, so there's no real difference in having CPU->GPU->NB-> Rad1-> Rad2 -> Res-> Pump.
    Another possible is to have Pump-> CPU-> Rad1-> GPU-> NB-> Rad2-> Res.
    That should get fairly low GPU temps too, as there's a rad before it to lose some of the CPU energy.
  6. Nexxo
    23 Oct 2001
    Different sequences will not make any difference in performance. Check your laws of thermodynamics, guys, and think about it. ;)
  7. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Without heat pumps you aren't going to see extreme results unless you accidentaly forgot to make a complete loop including every comopnent.
  8. silentphoenix
    silentphoenix What's a Dremel?
    1 Sep 2004
    Gratz mate - the first loop is usually the most memoriable (its either the one that fries all your parts or just your first step in finding another reason to memorise your credit card details :D)
    Thats what i was thinking, but water will be different temps in the loop (by a small amount) and will be coolest after having those 2 rads after each other. So having the coolest water flowing to the CPU first would make cooling of the CPU most effective (as there is a greater temp difference), but cooling of the following componants *slightly* less effective. All in the energy dissipated by the rads, is the same (and diff loop layouts) but the contribution of heat to the water from various part of the loop is different.
    This is all based on the assumption that the greater the temp difference the greater the cooling effect of water .... im assuming that:
    - if water is 30 deg and CPU block is at 60 deg then heat will transfer to the water
    - if water is 60 deg and CPU block is at 60 deg then heat transfer between the 2 is neglible
    - if water is 90 deg and CPU block is at 60 deg then heat will be transfered to the CPU block
    Granted figures are a major exaguration (sp?), but underlying idea seems sound - the greater then temp diff between the block and the water then the more effect the water will have on cooling. Saying that, in a real WC loop the temp diff would probably be minimal (hence the reason why people care less about the order - apart from res>pump - and more about the neatness).
    I could be wrong though, just my 2 pence :D
  9. AlexB
    22 Dec 2005
    Well, it seems to be holding tight - so windows is now being installed.
    I need a fan controller, too, as my Akasa fans are pretty loud when on full blast (which they are, at the moment.
    Thanks for the replies. I'm pretty happy that its working, so if it wont make a huge difference, im not sure I'll bother changing it for now.
    I am hoping now it wont fry my hardware.. ha ha
  10. Callum
    Callum What's a Dremel?
    4 Apr 2006
    After me...
    The First Law of Thermodymamics:
    Heat is work and work is heat
    Very good!
    The Second Law of Thermodymamics:
    Heat cannot of itself pass from one body to a hotter body
    (scat music starts)
    Heat won't pass from a cooler to a hotter
    You can try it if you like but you far better notter
    'Cos the cold in the cooler with get hotter as a ruler
    'Cos the hotter body's heat will pass to the cooler
    First Law:
    Heat is work and work is heat and work is heat and heat is work
    Heat will pass by conduction
    Heat will pass by convection
    Heat will pass by radiation
    And that's a physical law
    Heat is work and work's a curse
    And all the heat in the Universe
    Is gonna cooool down 'cos it can't increase
    Then there'll be no more work and there'll be perfect peace
    Really?
    Yeah - that's entropy, man!
    And all because of the Second Law of Thermodynamics, which lays down:
    That you can't pass heat from the cooler to the hotter
    Try it if you like but you far better notter
    'Cos the cold in the cooler will get hotter as a ruler
    Oh, you can't pass heat from the cooler to the hotter
    You can try it if you like but you'll only look a fooler
    That's a physical Law!
    Oh, I'm hot!
    Hot? That's because you've been working!
    Oh, Beatles - nothing!
    That's the First and Second Laws of Thermodynamics!
  11. silentphoenix
    1 Sep 2004
    Errrrmmmmm... me thinks you should audition for 'Barney (the purple talkin dino) goes to College' :D
  12. Callum
    4 Apr 2006
    *Barney wandering around every night with blazing red eyes and an unsteady stagger*
    Hi there boys and girls! My name's Barney! I love you all! Let's have a big hug!
    *Falls over*
    There are several people on my floor who sound exactly like this actually. :p
    *ahem* back on topic :p
  13. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I've personally tried different variations on similar loops. The conclusion is that it honestly doesn't matter. I try to make the loop the shortest I can and put the cpu right after the pump so it gets the most turbulence. Of course now I'm running a pelt on th cpu and gpu each with their own loops and 360mm radiators.....I need to quit.
  14. Breach
    Breach Modding in Exile
    20 Jun 2005
    Yeah it really doesnt at all. Just go with the setup that streamlines your loop and has the shortest tube lengths between your blocks and components.
    I remember my first, I blew up my system >< I rushed it though, and I shouldnt have. Later attempts were much better :)
    So my lesson to you is dont rush it:) Check for leaks constantly for the first week to make sure there are no super slow leaks.
  15. Nexxo
    23 Oct 2001
    Exactly. Mine is a short loop. The GPU comes before the two CPUs; the whole lot is adequately cooled on a single BIX. Not bad for a dual Opteron 250.
    Of course, the inlet tube from res to pump is huge to prevent cavitation (good drain from the res also means less chop and fewer air bubbles). The res is on top and the last item in the loop, pump is at the bottom. There are no sharp kinks.
    It is all about planning.
  16. AlexB
    22 Dec 2005
    my CPU temp hasnt gone above 28degs so far =) That's on a A64 4000 (2.6) clocked to 3gig.
    Not too bad..
  17. WhiskeyAlpha
    WhiskeyAlpha What's a Dremel?
    5 May 2006
    Nice temps Alex.
    Out of curiosity, what are you using for coolant there?
  18. AlexB
    22 Dec 2005
    de-ionised water, and a bit of car antifreeze ;) ha ha.
    goes upto 34-36degs after an hour of GTR2.
