My Future Rig Setup... Any Good?
Discussion in 'Hardware' started by ImInTheZoneBaby, 4 Nov 2007.
  1. ImInTheZoneBaby
    ImInTheZoneBaby Bring it on sucka!
    8 Aug 2007
    Hey guys, I am soon to be selling my computer, and upgrading to something... more powerful =)
    I was wondering if everything here, would work fine together. And, I am also open to criticism on the hardware I have chosen. If you find better, for around the same price or you reccommend something else. Let me know.
    Well, here are the specs:
    Computer Parts – Intel Quad Core + 2GB RAM + 8800GT OC + SLI READY (Base Unit)
    Case: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=452016 (£59)
    Aspire X-Cruiser Black Midi Tower with Window w/o PSU
    Motherboard: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=529752 (£68)
    Asus P5N-E SLI NF650i SLi, S 775, PCI-E (x16), DDR2 533/667/800, SATA II, SATA RAID, ATX
    DVD Drive: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=672899 (£18)
    Samsung SH-S202N/BEBN 20x DVD±R, 16xDVD±DL, DVD+RW x8/-RW x6, PATA, Lightscribe, Black, OEM inc. Nero
    Graphics Card: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=693200 (£182)
    512MB BFG Technology 8800GT OC, PCI-E 2.0 (x16), 1800MHz, GDDR3, GPU 625MHz, 2x Dual Link DVI-I, Fan
    Processor: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=643237 (£167)
    Intel Core 2 Quad-Core Q6600 G0 SLACR, 95W, S775, 2.40 GHz, 1066MHz FSB, 8MB Cache, Retail
    RAM: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=402849 (£54)
    2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800), 240 Pins, Non-ECC Unbuffered, CAS 4-4-4-12
    Total: £548
    ~~~~~~~OPTIONAL/FUTURE UPGRADE~~~~~~~~~~
    Intel Quad Core + 4GB RAM + 8800GT OC SLI + 800W PSU
    PSU: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=695914 (£100)
    800W Gigabyte ODIN Pro 24 PIN SLi/Quad Ready
    Extra Video card: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=693200 (£182)
    Extra RAM: http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=402849 (£54)
    Final Total: £884
    Well, there you have it. Some of the hardware for my new setup I should hopefully be getting. I was wondering, everything there.. Would it run perfectly fine together?
    P.S. Ignore the fact that some of the hardware is missing, (PSU for base unit, HDD's) ect.. I have those at home.
    Oh, and would a 550W PSU manage the base unit? I would like this to be answered. =P
  2. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    looks great. and yes, a 550w should have no trouble, provided its a good quality one.
  3. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Depending on which one. If it's the stock aspire 550, then no.
    I suggest the Corsair HX 620 now, and no odin 800 later. You won't need it.
  4. Seth
    Seth What's a Dremel?
    14 Mar 2002
    I wouldn't go for that mobo. 650 is an old chipset now.
    Other then that yeah looks good.
  5. Major
    Major Guest
    My advice.
    Change the brand of the 8800GT to EVGA, so that you can upgrade within 3 months of purchase if you "want" to, just pay the difference.
    Also I think the eVGA cards are in this week, and BFG are in the next few weeks.
    PSU: I like Seasonic, and this one is Modular. http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=475254 - Same price.
    Case: Don't like it personally, looks a little plastic, but you might like it. :)
    HDD: Are you getting these? If so Seagate are great, and cheap!
  6. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    looks pretty sweet.
    if you are getting a hdd, the samsung spinpoints are very good vakue for money, 500GB £80 and there very quiet aswell. also i would recommend getting a new heatsink/fan, other than using stock (which i am assuming you are using as no other mention of a h/f any where else) i use a freezer pro 7, cheap and does the job great!! if not there are others out there to that might suit your needs better!
  7. Brett89
    Brett89 Minimodder
    15 Dec 2005
    I have a P5N-E SLi. I like to play games and do some overclocking, does them all pretty well. One of the best bang for you buck motherboards.
  8. Guest-16
    Guest-16 Guest
    NOT the P5N-E SLI - it has serious issues with chipset cooling. Wait a few weeks if you want nForce :worried: EDIT: Or, not :|
    I dont know the details yet, mind.
  9. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    The Corsair HX series are rebadged Seasonic units anyway :idea:
    And if he wanted anything more powerful than (i.e.) a 620w Corsair HX - for future-proofing... then I'd recommend a 750w PCP&C Silencer 750 Quad - for just £79.99 / £93.99 :rock:
    (Scan don't appear to stock PCP&C?)
  10. ImInTheZoneBaby
    8 Aug 2007
    Th graphics card I listed was definately subject to change, and I was going to buy the Zotac overclocked card, it is cheaper and delivers crazy performance. It scored 1-2fps under the GTX in the Crysis Demo.
    About the motherboard, you believe I should wait? Is a new series of motherboard being released, or something? If so, im guessing that would raise the price above the motherboard i've selected here...
