Notebooks My girlfriend managed to destroy both of her USB ports!
Discussion in 'Tech Support' started by ry@n, 19 Jul 2010.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
    Hi,
    So she comes running to me today and shows me that both of her USB on her laptop have been completely destroyed, I mean one is just an empty hole and the other looks like it had been raped by a screw driver! She has no idea how this happened.
    The Laptop in question is made by either Acer or Advent (I don't have it with me now) and it doesn't have any expansion slots so a USB card is out of the question. The only other connections are the Ethernet socket and the SD card slot.
    I really dont want to open it up and solder new USB headers in if I can help it but does anyone know how to connect a USB device to one of the other connections?
    I have showed her how to connect the laptop to her home network and access the USB port of another computer which is fine but isn't going to be a possibility on the move.
    I have also considered a USB network hub but these require mains power and probably a router?
    Any help would be great, thanks.
  2. Ant1981
    Ant1981 Minimodder
    4 Dec 2008
    So, both of her ports have been destroyed, one of them is just an empty hole?
    Sorry, but with my perverted sense of humour, this thread really is open for some dirty abuse.
  3. ry@n
    ry@n Minimodder
    31 Aug 2005
    Yea it was pretty intentional, witty titles grab peoples attention :D
    Seriously though, any ideas?
  4. ChromeX
    ChromeX Minimodder
    12 Aug 2004
    I guess the easiest method would be to use the sd card as an ad-hoc memory stick. Its a bit of a rubbish solution since aside from laptops you dont see too many sd readers knocking about. Or maybe, if she doesnt already have a router, use a crossover cable to connect the laptop to another computer and use the USB ports on there.
    EDIT: Just done a search and found these, no idea if they work as i've never seen them before http://www.amazon.co.uk/Female-Male-Ethernet-Connector-Adaptor/dp/B000MHO3Q8/ref=dp_cp_ob_ce_image_1
    thehippoz likes this.
  5. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I'd be wondering how she managed to damage the laptop so badly. I mean it doesn't just "happen".
  6. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    I'd open it up and solder it back together, while it's open I would clean out the heatsinks too.
    Just my 2 cents
  7. dazedandconfused
    dazedandconfused generic babble ->
    26 Jun 2009
    THIS
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Does it have an express card slot? I know they make express card thingies that give you extra ports like USB 2.0, 3.0, eSata..........
  9. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    I like cromes idea.. but it doesn't look like it provides power like a usb port
    it's really not that complicated to solder parts back into a laptop.. why is one of them a hole and the other one burned up- it sounds bad
  10. ry@n
    ry@n Minimodder
    31 Aug 2005
    I never knew these existed, thanks. Not sure if it would function as a regular USB port and it wouldn't provide the 5v needed for powered devices.
    Turns out she lent the laptop to her little brother to play Runescape... and somehow it came back in that state :wallbash:
    The laptop has no expansion slots.
    It looks like the one has just become detached and fallen out, or inside the laptop itself. The one is still intact but it looks as if its been stabbed several times with a sharp object. I guess im just going to have to crack it open, I will post back with pics soon.
  11. davidm
    davidm Minimodder
    30 Jun 2007
  12. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Make sure little brother pays for any repairs- either with pocket money, or a firm clip round the ear.
  13. *brian*
    *brian* What's a Dremel?
    23 Jul 2010
    You'd think after scrapping one USB socket they'd look after the other remaining one!
  14. confusis
    confusis Kiwi-modder
    5 Jan 2006
    no serial port?
    EDIT: nvm - i've seen serial to usb adapters but can't find one the other way round
  15. Sterkenburg
    Sterkenburg To mod or not to mod...
    2 Oct 2005
    The first link won't work as a USB port (it's simply a converter - if you plug in a USB device, it won't know what's going on.)
    But this davidm's device WILL work:
    Unfortunately, you would probably need a switch or something to use it. Either that or connect the laptop to the internet via wireless so the wired port isn't used, and just run a DHCP server on the laptop for that port.
  16. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    those usb a to male ethernet, are not for connecting usb devices to the ethernet port of a computer, but rather to be able to connect a usb device over a longer distance via ethernet cable, to another ethernet to usb adaptor.
    replacing the sockets would be the best bet. if you can get them, be careful, because some are reversed(solder above, or below the main board) which means you could incorrectly power the usb devices. i would send it to a specialist repair centre to have it done properly.
    if that much damage has been done to the sockets, there is a good chance the usb controller circuits could also be damaged.
    sterkenburg has found a solution that will work for existing networks :)
