Case Mod - In Progress My Glass & Steel Orange Graphite 600T
Discussion in 'Project Logs' started by Dave2010_TA, 28 May 2012.
  1. Bitwacker
    Bitwacker C# forever
    9 Nov 2009
    I just love this build - just wish I had the skill/space to attempt something like this
  2. Dave2010_TA
    Dave2010_TA Minimodder
    25 Feb 2012
    Thank you so much Bit!!! With the time, you'll become a good modder!!!
  3. The boy 4rm oz
    10 Apr 2008
    Those reservoirs looks stunning, excellent work :thumb:.
  4. Dave2010_TA
    25 Feb 2012
    Thank you so much, I need to mod!!!!!!!
  5. Dave2010_TA
    25 Feb 2012
    I'm back guys, after having gorged on well during the three-day festival, go on with the show the progress of the mod.
    I had to give a sprucing up some special protrusions on the front door, as it came into conflict with the internal structure.
    I continued, then cutting out the bulkhead where necessary, to put the little frame of the new window the bulkhead.
  6. Dave2010_TA
    25 Feb 2012
    I continue with the installation of front and stainless steel tanks inside the case.
    See you soon with new up!
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Those reservoirs look soooo nice in there. :jawdrop:
  8. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    this will look awesome! :p Nice work, and you are welcome to watch what i will do for my own 600T :p when i get my hand's on it.
  9. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Very nice-I like reservoir placement.
  10. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    thats too sexy to be shown on bit-tech ;D
  11. Dave2010_TA
    25 Feb 2012
    Thank you very much guys!!! :thumb::thumb:
  12. Dave2010_TA
    25 Feb 2012
    I'm back. These days I started to apply the first glass in secure areas that I will not go to touch.
    I brushed with 500 grit paper on the bottom panel of the case and the two rear panels on the left.
    After that, I proceeded to move the reservoir and drill new holes in the panel, because they were too close to the 24-pin connector on the motherboard and would have interfered.
    The glasses were fixed with transparent silicone Saratoga. The silicone in excess will be removed easily with the aid of a cutter.
    I applied these two heavy wood on top of the glass, so that the silicone was well crushed and sticking well on steel.
    I have positioned the windows of steel that I cleaned with the diluent and satin all individually from both sides (in such a way that once mounted does not have to stay there to check what is the side put better). As you can see in the second photo, I glued the spacers transparent Plexiglas, to bear the radiator and attach to the bulkhead.
    Tomorrow during the day I would be able to finish the rear bulkhead, or apply the windows of glass and fix some details.
    On the back of the windows of glass, I shall apply a steel panel that covers them entirely, so that, once positioned the LED stripe along the perimeter, this reflects the light and illuminates the windows.
  13. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Looking very nice and I love that mobo + reservoir setup.
  14. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Stunning work Dave!
  15. Dave2010_TA
    25 Feb 2012
    Thank you very much guyzz!!! :D:D
  16. Dave2010_TA
    25 Feb 2012
    Work is continuing.
    First, with the Dremel, I improved the slots in the bulkhead of the case, to correctly position all the windows.
    After that, I drilled the panel that I spoke to you yesterday and I set the four side screws that I put, longer than the other, just for this reason.
    Then, I put silicone in the steel windows, after having first cleaned with a rag and thinner, to remove all traces of dirt and make sure that the silicone will adhere properly.
    Then it was the turn of the radiator.
    With this method I set the Cooler Master MegaFlow to mask rad, with M3 screws black. Then I used instead of 20 mm long M4 screws to fix it to the case.
    The Corsair stock mounts of grommets in the holes for the front fan which was utilized to secure the rad, so as to avoid vibrations on the cabinet.
    I also inserted the front glass panel to verify that the thickness of the same does not interfere with the rad, which in fact does not occur.
    Bye!
    Dave
  17. Dave2010_TA
    25 Feb 2012
    But now I have a problem, do not think small. Take a good look these pictures below.
    I need your help guys, as the coupling system of the partition right, interfere with the stainless steel front panel.
    There are two possibilities: make a hole in the panel to ensure that the fastener is inserted or remove the hook and with a panel of steel, shaped perhaps with some oddly shaped, I try to fill the gap.
    What do you think? Other solutions? It 'so that I think, but my brain is stopped at these two options.
  18. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Are you painting the case orange? You should get the all glass panel from MNPCTech
  19. Dave2010_TA
    25 Feb 2012
    I'm thinking about the orange painting.
    I designed the panels and a glass factory made me them. MNPCTech makes glass panels?
  20. TheGreatSatan
    5 Aug 2005
