Graphics My GPU seems to have disappeared
Discussion in 'Hardware' started by kissinger, 15 Dec 2014.
  1. kissinger
    kissinger Minimodder
    6 Dec 2011
    When I turned my PC on this morning my monitor didn't show anything and only displayed when I switched to using the iGPU on my motherboard, via HDMI. I've been into device manager and my GPU (a HD7970) isn't there. I've been into my boot menu and my GPU settings are set to 'auto-detect', and I've also installed the latest version of CCC just to see if that would help, but nope...
    Any suggestions as to things I could try?
    Specs:
    Mobo: Asus IV Gene-Z (G3)
    CPU: i5 2500k
    GPU: AMD HD7970
    Ram: 8GB 1600Hz Ripjaws
    SSD: Crucial M4
    OS: W7
  2. creative
    creative 500rwhp
    23 May 2014
    is it powering up? fans spinning etc?
  3. kissinger
    6 Dec 2011
    Yeah the fan's definitely spinning, and what's weird is I've not made any significant changes to software or hardware for a while. It was working fine just yesterday.
  4. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    Hi Kissenger,
    Can you try a different connection to the gpu, DVI maybe? Might also be worth trying to reseat the card in the pci-e slot just to rule that out.
  5. silk186
    silk186 Derp
    1 Dec 2014
    Also check your BIOS settings to make sure it detects external GPU first.
  6. kissinger
    6 Dec 2011
    I thought about doing this, but what would I do if it doesn't work?
  7. kissinger
    6 Dec 2011
    Thanks Matt, but I'm afraid that hasn't worked. Just cleaned out and reseated and no luck.
  8. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    Do you have any other computers at home you could test on?
  9. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    Could you try switching pci-e cables too, just to rule that out?
    Below would be the next thing I'd try.
  10. kissinger
    6 Dec 2011
    I've just tried switching over. Still nothing on the display, still nothing in Device Manager. Unfortunately I don't have a second PC to test it out in.
  11. spolsh
    spolsh Multimodder
    4 Feb 2012
    Have you tried a different PCIe slot ? (if there is one)
  12. kissinger
    6 Dec 2011
    That might be an idea. I assumed my board didn't have a 2nd PCIe slot because it's micro-ATX but I just checked the Asus site and it says it's got 2.
    I'll report back later. I sort of hope that it doesn't work though, because at least the card is still in warranty :D
  13. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    Let us know how you get on. :)
  14. kissinger
    6 Dec 2011
    Well I tried the other PCIe slot and... it worked!
    Which is sort of good and sort of bad. I suppose it's safe to say the GPU works (if it works it one PCIe and not the other, surely it has to be the PCIe that's busted, right?), but now I'll have to RMA my motherboard.
    Asus' warranty is 3 years, right? If so, I have exactly 3 days to get it back to Scan/Asus :eeek:
    Edit: just out of interest, does anyone know if I will get worse performance using the 2nd PCIe slot on this board? Underneath the 2nd slot is printed 'x8' in big letters, but the Asus page for the board says they're both x16.
  15. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    they will be both x16 probably, but if both were populated the second one would become x8, if my thinking is correct
  16. AMDMatt
    AMDMatt AMD Rep
    9 Sep 2014
    At least you discovered what the problem is. If you raise the rma immediately then you should be ok. Or you could just keep using the second slot. If you've no plans to add a second card, that's what I'd do most likely. It should run at x16 as long as the first slot is not occupied.
