My HDD fire
Discussion in 'Hardware' started by Hardware150, 13 May 2007.
  1. Hardware150
    Hardware150 Minimodder
    8 Jul 2006
  2. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    Looks pretty bad. Anything important on that drive?
  3. Hardware150
    8 Jul 2006
    thankfully it was just for backups and my smallest cheapest drive, i just repaired one of my 500gb drives because the data connector got snapped off yesterday
  4. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    That's the reason i dont have Maxtor's in my house... They are really too hot and unreliable. Every time i have had one it died on me..
  5. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Think its about time i got rid of my maxtor hard drive
  6. Hardware150
    8 Jul 2006
    the singged one is still working fine
    Your hard disk is a Maxtor 6B250S0 with firmware BANC1E00.
    The average temperature for this hard disk is 38C (MIN=27C MAX=50C) and yours is 28C.
    Your hard disk's S.M.A.R.T. attributes are now being analyzed and a full report about the reliability, health and status of your hard disk is generated:
    Your hard disk is not below any attribute threshold. This is good.
    Your hard disk was never below any attribute threshold. This is good.
    The overall fitness for this drive is 94%.
    The overall performance for this drive is 94%.
    although i am cooling it to the max now...
    http://i48.photobucket.com/albums/f235/davidshelley150/DSCF0463.jpg
    http://i48.photobucket.com/albums/f235/davidshelley150/DSCF0466.jpg
    (ive turned the air conditioning off now as when it gets down to 16 you can feel it) BEST PURCHASE EVER IS AN AIR CON
    Update
    Found some before images
    http://i48.photobucket.com/albums/f235/davidshelley150/DSCF0156.jpg
    http://i48.photobucket.com/albums/f235/davidshelley150/DSCF0155.jpg
    http://i48.photobucket.com/albums/f235/davidshelley150/DSCF0153.jpg
  7. hitman012
    hitman012 Minimodder
    6 May 2005
    What power supply are you using?
  8. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    Just whats gone through my mind :lol:
    Worried about leaving my comp on all the time too now, spose bits of it can catch fire whenever though, guess I will buy a smoke alarm :worried:
  9. teamtd11
    31 Aug 2005
    Its a Corsair HX Series 620W In that PC
  10. Guest-16
    Guest-16 Guest
    Focus, please! It's digital so take it again!
    Looks bad though, only drive I've set on fire was from shorting it. Give Maxtor a bell and tell them about it imo.
  11. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    PLUS, I know the stacker module can take 4 drives but I don't think its a good idea to put that much heat in there tbh, I've got 3 in mine but I am looking for a nexus drive away for my raptor.
  12. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    Wow, that's pretty bad. Good thing it didn't cause a serious fire.
  13. culley
    culley What's a Dremel?
    12 Jul 2006
    ^Or burn any other components.
  14. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    :S i use maxtors in every pc i've owned. still got a 40MB one in a 386 machine and a 500MBG one in a 486 machine going strong, never had a problem.
    something tells me it's more likely to be your manhandling of your components than the manufacturer at fault, here...
    installing stuff in a running machine? never really a good idea. sorry but seriously, you brought this on yourself.
  15. keir
    keir S p i t F i r e
    5 Oct 2003
    lol is that hdd from normanby?
  16. DougEdey
    5 Jul 2005
    There's no rubber tyres in that picture.
    I've seen this happen loads of times, normally the data is recoverable by switching the PCB
  17. teamtd11
    31 Aug 2005
    the 500GB was my fault, i pulled the hard drive cage out the frount of the case, to swap the fan.
  18. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Was it by any chance a Diamondmax 10 200gb SATA1? Those have quite a few problems. That EXACT IC went pop on my DiMax 10 200. I called Maxtor, and their customer support (real people) set me up with the rma details, and a week later I had a Diamondmax 11 300gb in my hands.
    It is not a power supply or heat factor. It is bad QC on that IC. My maxtor drives run cooler than comparable Seagates that I have, while being quieter and faster.
  19. Jipa
    5 Feb 2004
    Haha that's pretty serious ****.. My first, last and only Maxtor also let out some nasty smoke, but didn't catch fire. One chip was cracked in closer inspection.
  20. keir
    5 Oct 2003
    WTF?
