Intel Core i7 920 D0 Stepping (ordered) Asus Deluxe V2 Antec p193 Patriot 1600MHz Viper Series Low Latency (8-8-8-24) Antec CP 850 Microsoft Windows Vista Home Premium SP1 64-Bit - OEM (ordered) Samsung SpinPoint F1 1TB Noctua NH-U12P SE1366 CPU Cooler Arctic Silver 5 Thermal Gtx 260 SLi Scythe Kaze-Master 5.25" Fan Controller - Black This is what ill be ordering! i take picture and let you know how it goes. before i click buy, any advice on items im buying? Does anyone know if the Noctua NH-U12P SE1366 CPU Cooler Fits in the P193 The max height of a CPU cooler in the P193 is 160mm. Noctua max height is 158 with fans! Regards, Jeff Antec Customer Support
yeah drop vista 64 and get win7 RC1 instead. save you about £80-90. The noctua isnt the best CPU cooler although it is very quiet and is very good. TITAN fenrir is better but noisy. hmm looking at the RAM how much is it ??? i see you opted for low latency when in reality latencies make very little difference in performance on an intel platform (used to on old athlon skt 939 and below, not sure on phenom) ive ran benchamrks on my i7 machine with 8-8-8-20 and 9-9-9-24 and makes no recordable difference.
Bindi Edit: Why don't you keep a lid on your negative sarcasm? Oh, it'll fit, if it doesn't cut a hole in the side of your case. EDIT: Oh, PS: It'll fit, it's built to fit in average cases, and the P193 is bound to be built to the average width.
You should seriously consider putting that I7 under water, it will allow you to overclock way over 4 GHz. It will increase your build cost by around £150, but I reckon it's worth it. The excellent folk at Bit-Tech have recently reviewed a good ready-built watercooling kit, go on you know you want to!! http://www.bit-tech.net/hardware/cooling/2009/04/30/swiftech-h2o-apex-ultima/1
Looks sweet. I think the NH-U12P cooler will fit, it easily fits in my Lian-Li even though it does look massive.
lol i didint know the answer since i have never owned the CPU cooler or the case. didint want to lie now
I have the answer from antec support The max height of a CPU cooler in the P193 is 160mm. Noctua max height is 158 with fans! Regards, Jeff Antec Customer Support
+1 Fits in mine but be aware - it is a real bitch to fit the fans on it in tight spaces. Near-as-makes no difference silent, though.
Thats a soild recommendation to water cool, and a very worth while read, great review I enjoyed that.
