Modding My Itron VFD - revisited
Discussion in 'Modding' started by Enak, 2 Nov 2002.
  1. Enak
    Enak Also known as Kane
    23 Jul 2002
    Well, when I first got my Itron VFD I said I would take some better photos when I got my new camera... I've got the camera and also remade the bezel.
    I had planned to make the cutout (which was milled out) about 25mmx85mm but I got a bit carried away and it ended up a bit bigger (approx. 120mmx30mm). I think it looks pretty good with the cutout the size it is.
    The filter is the dark blue one available from Maplin (QZ71N). Unlike the filter supplied with the kit the dark blue from Maplin gives the display a much stronger blue colour and I would highly recomend it.
    As with my last bezel the filter and display were attached using double-sided carpet tape.
    The blank milled bezel
    Apply Double-sided carpet tape (it's like double-sided Duck tape)
    Carefully cut round the hole
    So the tape isn't covering the window
    Peel off the backing and stick the filter to it.
    Attach the VFD in the same way and all done!
    You can also use bolts stuck to the inside of the bezel (using something like araldite) to mount the VFD but I've found the tape does the job just as well.
    If you are thinking of making your own bezel I suggest you have a look at this
    If you've never seen one of these before have a look at the review
    And now for you viewing pleasure a view of the whole case.
  2. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    Dude... that looks really sweet, clean job too... Well done there... Did I notice website pimpage on that VFD too...
    :rock:
  3. Enak
    23 Jul 2002
    Thanks... I'm rather pleased with it myself :clap:
    That'll be my website on the VFD.
  4. CharlieCat
    CharlieCat What's a Dremel?
    12 May 2002
    Very nicely done mate :D
    I just got my VFD - but I got the larger one :naughty:
    You serious 'bout using double sided sticky tape to attach the VFD to the gel stuff which in turn is stuck to the blanking plate :naughty: I would have thought it too heavy and if it's that's sticky how do you get it off again ?
    Anyway, I'm going to get me some of that gel stuff from Mappers as I was a tad dissapointed with the stuff supplied - still too green looking for my liking.
    Cheers, CC
  5. fohkus
    fohkus What's a Dremel?
    12 May 2002
    that looks awesome man.. lemme see ur entire case WITH ur vfd mod :)
  6. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    Very nice :D
    /me getting a VFD soon...:rock:
  7. iSteve
    iSteve What's a Dremel?
    3 Jan 2002
    I'ld love a VFD ... with a little shorter pricetag, tho >=)
  8. iamwhoiam
    iamwhoiam What's a Dremel?
    20 Apr 2002
    nice
    how much is the vfd? did you just contact noritake-itron-UK?
  9. Enak
    23 Jul 2002
    Can't remember how much I payed... it was the special offer price, I got it right at the beginning from Itron UK.
  10. jethro
    jethro Modthusiast
    19 Mar 2002
    ooo purty. how much does those run?
  11. ChriX
    ChriX ^
    30 Aug 2001
    Woo! That does look uber purdy :D
    Nice, clean job Enak :clap:
  12. pheonix
    pheonix Toot Toot!
    14 Mar 2001
    Nice work, very clean. I like the way it combines with the colour of the case door :)
  13. relix
    relix Minimodder
    14 Nov 2001
    wiiii, very nice :D
  14. Enak
    23 Jul 2002
    fohkus,
    I've added a pic of the whole case to the first post.
  15. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    Anyone get one of those that's from the US? I've always wanted to hear an actual (not approximate) price on those - I'm loving my B.G. Micro but I'm wanting a graphic VFD now..
  16. Enak
    23 Jul 2002
    Probably best to post that on the main article thread as it will get seen by a lot more people.
