Modding My l33t Modding Skills
Discussion in 'Modding' started by Harrison, 10 Jul 2004.
  1. Harrison
    Harrison What's a Dremel?
    10 Jul 2004
    I am a first time poster, for a few weeks lurker. Now on to my joke mod :D
    Today I was sitting around my house trying to think of something to do when it hit me. I will make a computer case !! :rock:
    I then began the planning design and finding materials around my house, since i didnt have much i couldnt go for that fancy plywood i used cardboard :hip:
    I then went a measuring with my measuring stick and cut the pieces out. Since i didnt have any screws or fancy clear tape i used my favorite roll of ducktape.
    In the end this is what it came out to be. I had to tear a power button off another case because my card board one woud not work for some reason :mad2: . Tell me what you all think, tomorrow i am going to add a window :clap:
    NOTE THIS IS A JOKE MOD, I AM IN NO WAY IN CHARGE OF WHAT MIGHT HAPPEN TO YOU IF YOU ACTUALLY TRY TO RUN A COMPUTER IN A THING LIKE THIS
  2. diabloroker
    diabloroker What's a Dremel?
    4 Jun 2004
    i have that same exact case u have on the right.. thing is i only go 2 fans on the front i bet u got the older version with 4 fans huh?
  3. Harrison
    10 Jul 2004
    yeah, right now i have 3 in the front
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    ISTR there's a firm in Japan that makes cardboard PC cases.
  5. Skylined
    Skylined Minimodder
    3 May 2003
    Does it have something inside and working?
  6. SilentDeath
    SilentDeath What's a Dremel?
    28 Jun 2004
    Wow, awesome mod. The duct tape accents are where it's at.
    I can't wait to see the window mod. What dremel wheel are you using?
  7. Jedi
    Jedi What's a Dremel?
    16 May 2004
    very nice, cardboard is teh l33t :rock:
    u gonna add some fans to it?
  8. Harrison
    10 Jul 2004
    I got my window added and then decided to take some pictures of how i got my cdrom, motherboard, and power supply in there. I tried some screws but they dont hold to well in cardboard, so out came the ductape!!!
    after all that i went ahead and decided it was time to put the cdrom in there, again with ducttape!!! because when i went to add a hole in the front of the case for it to fit it just would not go :-/. Did i tell you all the many uses for ducttape?
    After that was done i knew i needed some ventilation in the case. I decided to add a blow hole at the top, i didnt have to use ducttape this time because the cardboard secured it pretty good.
    Any ideas on what i can use next? I am running out of them.
  9. Jedi
    16 May 2004
    where are the cold cathodes???
  10. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    ian w ur right check out the site cardboard cases is there nothing the japs wont do???
  11. noobidoo
    noobidoo What's a Dremel?
    8 Jun 2004
    lol run the computer
  12. shroom
    shroom What's a Dremel?
    6 Aug 2003
    lcd mod, and watercooling
    oh, and you could give it a nice paintjob too
  13. Nexxo
    23 Oct 2001
    I ph34r your l33t modding skillz. :worship: :D
  14. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Looks a bit boxie for my liking :worried:
  15. Skylined
    Skylined Minimodder
    3 May 2003
    Paint it silver!!! (AKA duct tape everything! :hehe: )
  16. jodathmorr
    jodathmorr What's a Dremel?
    19 May 2004
    I don't like the color. Try painting it? Brown is the new beige.
  17. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
    gotta agree with the water cooling, tho would go for the lesser used "sprinkler" mod would be awesome you could go for the soggy cardboard case then...
