Modding My Leather Briefcase PC --Phase 1--
Discussion in 'Modding' started by rups22, 31 Aug 2006.
  1. rups22
    rups22 What's a Dremel?
    31 Aug 2006
    Hi, i'm Rupert Ferder, 17yo, from the South of England
    Phase 1 of my Briefcase PC is COMPLETE.
    Still to go...Phase 2: Intergrated monitor, speakers and other mods
    Check out the pics and tell me what you think.
    Here are the specs:
    PCChips M848A Socket A Motherboard
    AMD Athlon XP (T-bred) 2100+ running at 1.8Ghz
    1Gb DDR333 RAM
    ATI Radeon 9200SE Graphics (Low Profile)
    Firewire+USB cards
    DVD/CD-RW Combo Drive
    This project has ben plagued by mishaps, from faulty mobos, to overheating PSUs...but everything works beautifully now.
    I started this project a year ago, and have slowly built it, as and when i can get the parts i needed.
    Carbon fibre panels are attached to the sides.
    Clear acrylic sheet protects the components.
    The front LEDs give POST signals, to analyse problems etc.. from the Motherboard analysis PCI card that is underneath the firewire/USB card.
    I had to order a PCI card riser from the US to get the cards on that angle.
    All the PCBs are Red, and so are the cable ties and main cables. :D
    It is all fully portable
    Because it was an expandable briefcase, the bottom half had to be permanently expanded using metal X struts, it gave me more depth to work with.
    Here are some pics, please give me your honest opinion
  2. mattthegamer463
    26 Nov 2004
    Damn buddy, shrink those pics up. 640x480 will do nicely.
    Nice job though, looks just like the briefcase PC I built a few years ago (it actually may be the same case) except yours is much nicer.
  3. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    Shrink those pics!!! And how does it vent when closed? Of dose it just run open.
  4. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    I've been thinking of doing the same for quite a while but...
    ? Why no shielding on the PSU? (painted red)
    Also, I'd paint the drive tray red & sleeve that big mass of cables (several sleeves, all red of course, just in case you need to change a part) I really like the diagnostic lights by the handle :rock: and the all red theme (from PBCs to cable ties) :thumb:
    The only negative thing I have to say is: It's a shame you didn't make a project log with a few construction details - problems & solutions can be quite helpful to others.
    :thumb: Nice first post & welcome to the forums :clap:
  5. rups22
    31 Aug 2006
    answersanswersanswers
    Thanks for checking out my mod.
    "And how does it vent when closed? Of dose it just run open."
    At the rear of the case, between the Motherboard and PSU, a fan hole will be cut and a, yes you guessed it, RED fan will be mounted to help ventilation when closed.
    "Why no shielding on the PSU? (painted red)"
    When the PSU had it's metal casing intact, it was way too high, so it had to go, also i like the way you can see what's inside :baby:
    "It's a shame you didn't make a project log with a few construction details - problems & solutions can be quite helpful to others."
    Unfortunately, when i started the project, i was a complete n00b (i am not much better now lol), and i didn't think to create a log.
    On hindsight, i really should have.
    I did however take pictures of the project, in the early stages; if anyone's interested
    Cool idea, i will bear that in mind.
    I was originally planning to use cable ties to "sleeve" the entire cable set, do you think it would look good?
    I.E, you woudn't be able to see the cables beneath, just cable ties!
    My brother said to me (after i had built the prject), that i should have painted the interior of the bottom half of the Briefcase Red/Covered in carbon fibre, i wish i had done that in the first place :blah:
  6. rups22
    31 Aug 2006
    Image sizes Fixed
    Image Sizes Fixed,full size images can be found at...
    High Res Images
    :clap:
  7. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    Cable ties are really only suited to either hold cables together, or to hold cables up outta the way (in a tower case).
    You can buy proper cable sleeving - in a variety of colours, from any good mod shop (i.e. Kustom PCs, Fleetwood Computers etc etc). It'll look much more professional than using cable ties :idea:
    Nice idea though. A new take on carrying your PC in a briefcase :D
  8. rups22
    31 Aug 2006
    bought!
    Cheers for the idea mate, i just bought this:
    Sleeving Kit
    And this:
    Akasa 80mm Red Fan
    Check out the rear of the case...i have cut a vent hole ready for the new 80mm RED fan
  9. MrMacomouto
    MrMacomouto What's a Dremel?
    28 Mar 2004
    Looking pretty good, you could paint those bits on the bottom matt black to cover them up.
  10. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    looking good, couple of things though:
    1. be careful with the ATF pin removal tool - very prone to breaking
    2. a TFT mounted in the lid maybe?
  11. mattthegamer463
    26 Nov 2004
    I was sleeving my PSU and really didn't want to take off the 20-pin connector, and I was able to squeeze the connector through 1/2" sleeving. Saved me a lot of trouble. Although, I didn't use heatshrink on any of the wires, so it would probably be impossible to use heatshrink.
  12. Tyinsar
    26 Jul 2006
    :thumb: That will look much better
    That's a shame but not the end of the world - red tape & a zip tie at the ends.
    How close does the stuff at the bottom come to the ground when set upright?
    I agree with MrMacomouto, the bottom grill would look better painted. Other ideas would be to 1) invert it so it goes into the case rather than protruding & being prone to damage, 2) put it just inside the case so only the screws & washers are outside, 3) (my preferred option) replace the grill with a black air filter. The third option might also help with another concern: is that outer case coating going to peal around the holes?
    How about a closeup of the side with all the inputs & outputs?
  13. rups22
    31 Aug 2006
    Cheers for the heads up regarding th pin removal, i will try to be careful
    Phase 2 mainly involves mounting a TFT in the lid.
    but i only have 3 cms depth to work with!
    any ideas?!
    "How close does the stuff at the bottom come to the ground when set upright?"
    The standoffs on the bottom of the case give ample clearance so the fan grill doesn't get damaged :D
    "you could paint those bits on the bottom matt black to cover them up."
    Personally i like the look of the rivets coming through, i will post some detailed pics of the underside, and you can tell me what you think
  14. rups22
    31 Aug 2006
    Sleeving Complete
    I have added an Akasa Red LED Fan at the rear
    All of the connectors have been replaced with red ones...
    And I have sleeved/heatshrinked all of the cables.
    I am going to add a couple of UV Cold Cathodes to which all the sleeving/cables/heatshirnk/connectors will react and glow!
  15. Tyinsar
    26 Jul 2006
    :clap: sleeves look much better :thumb:
  16. rups22
    31 Aug 2006
    UV Cold Cathodes Installed!
    Here are the pics of the cold cathodes in action
    i have sleeved them to try and make them more RED!
    Although i think further reddening will be needed...
    Here is a movie of the Computer in action
    Movie
    Let me know what you think...
  17. mattthegamer463
    26 Nov 2004
    If you wanted it super SUPER red you could take out the case lining and dye it red, then put it back in.
  18. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    You gonan blast the plexi and add leds?
  19. cire9753
    cire9753 What's a Dremel?
    16 Aug 2006
    looks pretty pink to me :p nice though, i had a red cathode and it glowed pink and my case was orange so i colored it with a orange sharpie and it worked great, i colored the actual cathde not the clear cover thing though
  20. CAYMAN
    CAYMAN What's a Dremel?
    16 Nov 2006
